Help! Need Suggestions for New HTPC - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #32 of 50 Old 12-11-2012, 01:36 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
For the price of that motherboard and ram you can get a better motherboard and ram.
Mfusick is offline
post #33 of 50 Old 12-11-2012, 01:39 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157294
$129 for Asrock Extreme 4 Z77 + Gskill 8GB DDR
Mfusick is offline
post #34 of 50 Old 12-11-2012, 01:40 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
8GB = $35 and the board = $95.
Mfusick is offline
post #35 of 50 Old 12-11-2012, 04:31 PM - Thread Starter
warscout11's Avatar
Hey, ya I saw that one, I saw a lot of bad reviews and I usually stick to either asus or gigabyte for motherboards just from my experiences in the past. It was hard finding a 1155 micro atx motherboard with decent reviews actually.
warscout11 is offline
post #36 of 50 Old 12-11-2012, 04:33 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Originally Posted by warscout11 View Post
Thanks so much for your builds! After reading this:
http://forum.xbmc.org/showthread.php?tid=146023
I'm gonna go with the amd build,
If you are going to run XMBC, Intel is not a good choice.
- You will disable DXVA2 with Intel, that means you use only CPU/software for video playback, Intel GPU hardware (many excellent ASICs in the die) will be unused (what a waste!).
- You can use DXVA2 as well as software solution with AMD.
That's why AMD Llano / Trinity is so popular in XBMC Forum.
renethx is offline
post #37 of 50 Old 12-11-2012, 04:36 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Originally Posted by Tiddles88 View Post
I'd take Intel. Cooler and faster. This reviews shows the i3 murdering the 5800K (other do too), even in a HTPC you don't want to sacrifice CPU grunt:
http://www.hardwaresecrets.com/article/A10-5800K-vs-Core-i3-3220-CPU-Review/1646/19
Anything to do with video playback?
The main task of a HTPC is video playback (in general), for which AMD Trinity / Llano is a lot better in many respects.
renethx is offline
post #38 of 50 Old 12-11-2012, 04:39 PM
Tiddles88's Avatar
Liked: 24
The main task of a HTPC is video playback, for which AMD Trinity / Llano is a lot better in many respects.
And? There is no reason to knowingly buy a slower CPU just because it excels GPU-wise. Even for an HTPC, I'd always take Intel first.
Tiddles88 is offline
post #39 of 50 Old 12-11-2012, 04:43 PM - Thread Starter
warscout11's Avatar
I can see what you're saying as far as dxva2 being unused with intel, but will that actually affect video playback? The gpu is unused, but since the intel can handle the software decoding anyway, is there a really a downside? I'm not sure, which is why I'm asking.
post #40 of 50 Old 12-11-2012, 04:43 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
No pissing contest guys. Both are good. I don't think it matters much for the OP.
AMD is better at the GPU stuff and Intel is better at the CPU stuff. It's that simple. Both are enough for his intended purpose on both counts.
Mfusick is offline
post #41 of 50 Old 12-11-2012, 04:45 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Well in simple speak I can try to answer you question so it makes sense. Can you run XBMC and play movies perfectly on an Intel based system? Answer = YES.
Mfusick is offline
post #42 of 50 Old 12-11-2012, 04:50 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Well, there is no reason to buy a slower GPU just because CPU is better. GPU is everything in video playback, the main task of HTPC.
- Decoding is done by a decoder in GPU: UVD (AMD) / MFX (Intel)
- Deinterlacing is done by stream processors in GPU (AMD) / Media Sampler+EUs (Intel)
- Post processing is done by stream processors in GPU (AMD) / Media Pixel Ops+EUs (Intel)
- madVR (if you are interested) uses stream processors (AMD) / EUs (Intel) exclusively via Diret3D API for its complex algorithms.
So CPU plays very little role in video playback.
SVP (Smooth Video Project) is an exception, that requires both CPU and GPU power (via OpenCL). A10 is just excellent in this case (good balance between CPU and GPU, and good CPU-GPU communication via improved memory controller). None of Intel can touch Trinity.
BTW a typical CPU-intensive task related to HTPC is video encoding. In x264 encoding, A10-5800K is roughly 20% faster than Core i3.
renethx is offline
post #43 of 50 Old 12-11-2012, 04:55 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Well, software solution is not that bad, but generally you'd better use DXVA2 / GPU hardware for better picture quality (deinterlacing by software sucks in my eyes) and for lower power consumption (not that big, but I still see 5-10W difference between DXVA2 decoding and software decoding with Intel SNB / IVB).
renethx is offline
post #44 of 50 Old 12-13-2012, 05:31 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Renethx,
In your opinion with a $5000 budget (high end) what's the best PQ and performance hardware choice ?
CPU + video card ? Which ?
And what software ?
Mfusick is offline
post #45 of 50 Old 12-16-2012, 07:11 PM
Puwaha's Avatar
Liked: 35
Is this a facetious question, or are you serious? I could help you spend a good portion of that $5000 to get you the best video and audio experience possible with a HTPC. Think high-end SVP and UltimateEQ.
Puwaha is offline
post #46 of 50 Old 12-17-2012, 02:44 AM
Makarios's Avatar
Originally Posted by Heuer View Post
Hey - I'm a "Dad" so please don't assume anyone over the age of 13 can't understand this stuff!
Well, I'm a granddad trying to keep up, too. Hope I can join this conversation...
I'm planning to build an HTPC for the main purpose of playing movies (also 3D) from my HDD. I won't go for compromises but just want top-of-the-line in the first place. Got a nice (hand-me-down) SilverStone case, power, BluRay, SSD and lots of HDD storage but need some recommendations:
- ATX motherboard w/USB 3
- decent processor plus a flat cooler
- video card
Anybody care to pitch in?
makarios
Makarios is offline
post #47 of 50 Old 12-17-2012, 03:27 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
renethx is offline
post #48 of 50 Old 12-17-2012, 05:16 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I am just trying to calibrate my potential compass.
Mfusick is offline
post #49 of 50 Old 12-17-2012, 10:20 AM
Puwaha's Avatar
Liked: 35
Ultimate Equalizer can perform serious room correction and equalization for a typical 5.1 on up to 12-16 channels of audio. It requires a 2.7GHz processor but the recommended setup is using an i7 CPU and above for advanced setups. The recommended sound cards are Delta 1010LT ones that are about $170 a piece.
Since I would be pairing this theoretical $5000 PC with SVP I would probably suggest a SB-E CPU and high-end GPU to cover the overhead of both applications.
A person willing to spend thousands of dollars on high-end audio hardware would want this ability to have control over the audio outPut of a HTPC.
Puwaha is offline
post #50 of 50 Old 12-21-2012, 06:13 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Wouldn't it be better calibrate audio on the audio level like on your receiver ?
Then just calibrate the HTPC to match that ?
My receiver has room correction.
Mfusick is offline
Reply Home Theater Computers
