Media Center Extender and MKV Playback Device - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-11-2012, 07:32 AM - Thread Starter
theshadow1234's Avatar
I have a 1gbit wired network at home 5 rooms and i am looking to setup a device for each room that i can flawlessly playback 1080p\720p mkv and avi files with no issues. Also I have a windows 7 media center pc with a centon quad tuner that i want to use and extend my cable signal to each room so i can watch and record tv. I read about the Ceton Echo extender and it looks like it's not ready for prime time.
Is there another device that can successfully do all of the above besides a HTPC at each room?
What are your recommendations?
theshadow1234 is offline
post #2 of 4 Old 12-11-2012, 07:47 AM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
I would recommend having two separate devices. No extenders do a great job with various file formats and high bit rate files. I have an Xbox 360 in each room for TV (and Netflix), and an HTPC running OpenELEC for my movies. You could substitute the HTPC for a content streamer like a WD TV Live or a Dune player.
I would love if one device did it all, but there are very few devices that can do live television and DVR.
lockdown571 is offline
post #3 of 4 Old 12-11-2012, 07:58 AM - Thread Starter
Could you use the HTPC as an extender if you already have another pc with a quad tuner? . I haven't been keeping up with the new stuff so i didn't know what was out there. I guess there still isn't a device that can do both. Maybe in the next 6 months something new will come out.
post #4 of 4 Old 12-11-2012, 08:04 AM
Quoted: 36 Post(s)
Liked: 87
I believe the tuners in the Ceton can be networked, so you can assign individual tuners from one PC to another PC on your network. Things get messy when you add more HTPC's to your network. I don't think the Ceton will reassign the tuners on the fly like the HDHomerun Prime (someone correct me if I'm wrong). Also, copy once protected shows will only play on the PC they were recorded on. Recording schedules are also not shared between multiple computers. It's also not easy to share non-copy once recordings between multiple PC's unless you have a WHS 2011 machine. Using extenders solves all of these issues.
Basically, the whole multiple PC route is a major PITA. Have one PC managing the tuners, and perhaps use that as a your main HTPC. Then use extenders + some content streaming device for other rooms in the house.
Reply Home Theater Computers
