Looking to build "budget" HTPC for another room in the house - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 38 Old 12-14-2012, 11:42 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Originally Posted by StardogChampion View Post
If you dig into what Intel HD graphics is on this CPU, it's the same architecture, EUs and speed as Intel 2000 HD graphics but with QuickSync and 3D turned off. The G860 is basically an i3 with some features turned off and a little less cache. Marketing... for a 2D HTPC the perceived performance should be identical between the G860 and i3-2100.
Yup.
That's why I got one for my server for $58
Mfusick is offline
post #32 of 38 Old 12-14-2012, 12:25 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
I have a G620 in my bedroom HTPC and it's rock solid. I say get the one you can find the best deal on. Performance isn't an issue on these CPUs. It's about finding the one with the features you want and then finding the one that's the sweet-spot pricewise. IMHO.
Great advice.
Even a G5xx would be fine. A G6xx is obviously a bit more powerful for another $10-$15. A G8xx would be basically the same power as an i3.
There is almost no real world difference- so whether you got a G630 or a G620 or a G6xx whatever... it's not going to matter.
I'd say you would be hard to notice a jump from the G530 to the G860. I think the G530 is 2.4ghz and the G860 is 3.0ghz ???
Stardog has the right advice. Buy the one you find a good deal on as they will all work great.
My personal value system is:
G6xx <$60
G8xx <$70
i3 <$80
If you can find all three buy what is in your budget. If you can find one of those... buy that as the best choice.
They are all great choices. It comes down to what you find the best deal on personally when you buy it.
Mfusick is offline
post #33 of 38 Old 12-14-2012, 12:32 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Here is what I would do:
G860 3.0ghz RETAIL BOXED WITH INTEL CPU FAN -$58 (use code GUMDROPS)
https://www.superbiiz.com/detail.php?name=G860BOX
Mfusick is offline
post #34 of 38 Old 12-14-2012, 12:36 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
and for $5 less you can have either the G645 or the G630
G645:$53
https://www.superbiiz.com/detail.php?name=G645BOX
G630: $53
https://www.superbiiz.com/detail.php?name=G630BOX
Or a worse deal on the G620: $55
https://www.superbiiz.com/detail.php?name=G620BOX
It's not really going to matter. Personally I'd spend the $5 for higher clock speed.
Mfusick is offline
post #35 of 38 Old 12-14-2012, 12:37 PM
dpn
dpn's Avatar
I saw this too. Great price.
Tiger Direct has a 160 GB SSD for $89 after a rebate. I just want something that's gonna work.
http://www.tigerdirect.com/applications/searchtools/item-Details.asp?EdpNo=5250507&sku=I69-7010
David
Originally Posted by pman555 View Post
Is this a good deal on a SSD? 120GB Verbatim SSD for $70, free shipping.
http://www.buy.com/prod/verbatim-120gb-2-5-sata-iii-solid-state-drive-ssd/227360950.html?ss?adid=18094&
dpn is offline
post #36 of 38 Old 12-15-2012, 10:10 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
What did you decide for your CPU ?
Mfusick is offline
post #37 of 38 Old 12-15-2012, 12:13 PM - Thread Starter
pman555's Avatar
Quoted: 42 Post(s)
I went with the G860 from Superbiiz. Ended up being $65 including shipping.
And since its coming from Edison, NJ (about 30 min away from me) it'll be here by Monday!
pman555 is offline
post #38 of 38 Old 12-15-2012, 09:13 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
Nice. I built two G860 PCs today for family who are buying them for their family for Christmas. What a great bargain.
StardogChampion is offline
Reply Home Theater Computers
