Video Card for HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-11-2012, 04:14 PM - Thread Starter
Teknologikal's Avatar
So I don't want to waste anyone's time, including my own =)
I have an HTPC that's about 4 years old. Other than graphics everything is up to date
Has a HD4700 card that's great, but HDMI is not HDCP Ready so I am using the DVI > HDMI
Also, no 3D support
What video card do you recommend?
- One HDMI port (Don't care about the rest)
- Fanless or Super quiet fan
- No gaming at all
- HDCP Compliant
- 3D Bllu-Ray Ready
- $50-$100
- No overkill or not underpowered
- No preference between ATI and NVIDIA
Just looking for solid picture quality for XBMC\Ceton\BluRay 3D
If there are similar posts, please post links. No unnecessary questions. I just want simple answers =)
Thank you in advance,
ME
Teknologikal is offline
post #2 of 11 Old 12-11-2012, 04:20 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
renethx is offline
post #3 of 11 Old 12-11-2012, 04:20 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
You should list your current motherboard and CPU to help us.
Mfusick is offline
post #4 of 11 Old 12-11-2012, 04:29 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
how about a cheapo card like this Asus ??
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121439
If you wanted good power:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161408
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150612
I would say any 6000 series RADEON under $45 is a good low end choice. I linked a silent model in my first link.
Stepping up but inside your budget a 6670 would give you more power. Do you need it ? If so check out second link.
Best choice under $100 is the 7750 like the XFX card I linked third. (I don't how quiet it is)
Mfusick is offline
post #5 of 11 Old 12-11-2012, 04:54 PM - Thread Starter
No, I have an older Bose LifeStyle 38 system. I will not be using the HDMI for sound, just video
I am at the office so I don't have the specs infront of me. If my memory serves me right I believe the MB is GA-EP45-UD3P (rev. 1.6) and CPU is Intel® Core2 Quad Processor Q9550
post #6 of 11 Old 12-11-2012, 04:57 PM - Thread Starter
Thanks Mfusick
I saw the HIS card previous as well. What do you think about it vs this http://www.newegg.com/Product/Product.aspx?Item=N82E16814102950
post #7 of 11 Old 12-11-2012, 05:14 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
That looks good if your case is large enough. HIS IceQ HD 6570 is good enough for all 2D/3D video playback tasks and will fit every normal HTPC case.
renethx is offline
post #8 of 11 Old 12-11-2012, 05:18 PM - Thread Starter
Yeah, Huge LianLi Case. Will do more research on these two
Any issues with fanless?
post #9 of 11 Old 12-11-2012, 05:18 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Originally Posted by Teknologikal View Post
Thanks Mfusick
I almost linked that card.
It's a fine choice.
Mfusick is offline
post #10 of 11 Old 12-11-2012, 05:19 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Not for non overclocking or simple movie playback. Nope.
perhaps runs a bit hotter but not a problem in a proper case.
Mfusick is offline
post #11 of 11 Old 12-11-2012, 05:29 PM - Thread Starter
Great. Thank you again
Reply Home Theater Computers
