So building the HTPC was the easy part.....HELP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-11-2012, 06:46 PM - Thread Starter
stamina1914's Avatar
Quoted: 106 Post(s)
So I just finished the PC build and as tough as it was, its cake compared to putting all the software on this thing. I need some help with media browser. Is it me or did anyone else feel defeated when you first came across the site?
So a few questions. I notice there were a ton of themes, theme bundles and "extras" I guess there called plug ins that you can purhase. Its a bit overwhelming particulary having to make sure you enter all your movies correctly. So any advice would be great.
Such as should rip a few movies first before I get started with media browser. Is one theme easier to navigate than the other? Should purchase a bundle or not and the advantages of doing so?
Thanks for the help.
stamina1914 is offline
post #2 of 10 Old 12-11-2012, 06:55 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Use chocolate theme. (Free)
Get CoverArt (Paid)
Inside mediabrowser click the wrench configure button thing in the top right. Set it for COVERFLOW and 320 size.
Next step: PROFIT.
Mfusick is offline
post #3 of 10 Old 12-11-2012, 06:56 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Also- USE MEDIACENTERMASTER on your MEDIA to get it all up to speed and organized.
http://forums.mediacentermaster.com/viewtopic.php?f=2&t=6348
Mfusick is offline
post #4 of 10 Old 12-11-2012, 06:57 PM
AnthonyB's Avatar
Use yammmm for proper naming. If you have a problem, use the index id from imdb and name the folder the index id.
AnthonyB is offline
post #5 of 10 Old 12-11-2012, 07:01 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Mfusick is offline
post #6 of 10 Old 12-11-2012, 07:02 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
What is yammmm ?
Mfusick is offline
post #7 of 10 Old 12-11-2012, 08:06 PM - Thread Starter
Quoted: 106 Post(s)
So is the index ID the entire URL or just the tt...... And do I still name the movie? For example if it is Batman, do I name it "Batman" or tt.......?
post #8 of 10 Old 12-12-2012, 07:43 AM
rshack's Avatar
Originally Posted by Mfusick View Post
What is yammmm ?
I think he put one extra 'm' in there. It's Yammm (Yet Another Media Meta Manager). http://www.sevenforums.com/media-center/10757-yammm-yet-another-media-meta-manager.html
rshack is offline
post #9 of 10 Old 12-13-2012, 06:24 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I'll check it out thanks
Mfusick is offline
post #10 of 10 Old 12-15-2012, 11:09 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Any updates OP ? Hows your build and experience going ?
Mfusick is offline
Reply Home Theater Computers
