Anyone else having trouble with MediaCentermaster ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-11-2012, 05:54 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Mine won't update anymore. Seems unstable and crashes since last update.
Mfusick is offline
post #2 of 11 Old 12-11-2012, 09:13 PM
Pagali's Avatar
Quoted: 12 Post(s)
I was having trouble with it, yeah. Crashes, freezing... I finally reinstalled the last downloaded version I had - 2.04 - and told it not to update automatically. Everything's working fine for now, I'll check back at their forum now and then to see where it stands.
Pagali is offline
post #3 of 11 Old 12-12-2012, 05:15 AM
tman247's Avatar
Quoted: 58 Post(s)
Liked: 53
Had the same problem since an update a couple of weeks ago. It went very unstable, so I rolled back to the previous version and turned off auto-updates. All working as expected, but I'm keeping an eye on the MCM forums until the problems are resolved.
tman247 is offline
post #4 of 11 Old 12-12-2012, 08:36 AM
user4avsforum's Avatar
Good to know to look out for problems with the latest version. I will be sure to turn off updates before I use it again.
Have you tried MetaVideoEditor as an alternative? I use MVE as my primary meta data manager and only use MCM to gather the actor images - if MVE did this I would not use MCM at all.
user4avsforum is offline
post #5 of 11 Old 12-12-2012, 09:53 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
It's working better now
Mfusick is offline
post #6 of 11 Old 12-12-2012, 10:12 AM
rsinclair's Avatar
Yeah, I've been having numerous crashing issues with MCM for the past couple of weeks, nearly making the app unusable. It's always been pretty stable up until now, but it looks like the constant updates (it seems to download a new .exe almost every day) have finally gone off the rails.
-R
rsinclair is offline
post #7 of 11 Old 12-13-2012, 05:24 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
It has been crashing much more recently. Yes.
Mfusick is offline
post #8 of 11 Old 12-13-2012, 07:24 AM
PFRboy's Avatar
If I ask MCM to process more than 15 titles at a time, it crashes.
PFRboy is offline
post #9 of 11 Old 12-14-2012, 12:45 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
I will check this out.
Mfusick is offline
post #10 of 11 Old 12-14-2012, 01:07 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
I have not had problems with MCM but I only do one or two titles at a time now. Actually I do it manually after creating the folder and while I'm using MakeMKV.
Sammy2 is offline
post #11 of 11 Old 12-15-2012, 05:54 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
I think it's the new build. Why does it need to update everyday ?
Mfusick is offline
Reply Home Theater Computers
