Quad-port Gigabit Intel card for media server ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-13-2012, 08:47 AM - Thread Starter
BruceD's Avatar
Quoted: 12 Post(s)
Liked: 30
Does anyone have specific PCIe recommendations for the model numbers of an Intel 4-port gigabit ethernet card that works great in a media server running ESXi (5.0u1 or 5.1) ?
Anyone have 1st hand experience with Intel PCIe models they are using in ESXi media servers ?
I've got the VMware compatibility guide, but that is sometimes a little vague.
BruceD
BruceD is offline
post #2 of 4 Old 12-13-2012, 10:21 AM
Aluminum's Avatar
Quoted: 22 Post(s)
Liked: 25
Nothing cheap, are you really slot limited? And if you are going to do VT-d do you really want to pass all 4 to the same VM? Thats how it will normally be, the other cards with onboard pci bridges usually won't pass cleanly.
A pair of very common (server pull) intel dual ports would be maybe $70 shipped.
When I stopped caring about super quiet: E5 1680v2 @ 4.5Ghz, 980ti, i750 SSD - JS9500 & Dell P2715Q for dual 4k@60 because reasons
SAN shares over 56Gb infiniband, microcenter + fleabay = severe risks to my wallet
Aluminum is offline
post #3 of 4 Old 12-13-2012, 02:12 PM - Thread Starter
BruceD's Avatar
Quoted: 12 Post(s)
Liked: 30
Thanks al.
You make a good point about the passthru.
Since my objective was to use this for a sw firewall, the dual-port would be sufficient.
Lots of reported problems with server PRO1000 type of cards and vmware.
Think I'll find the following from vmware compat list available on ebay?
  • ET Dual Port Server adapter (Intel 82576 Gigabit Ethernet Controller)
  • Server Adapter I350-T2
don't know if this vmware quote is important or not:
"For products based on the Intel 82576 Gigabit Ethernet Controller, version 1.3.8.6.3 of the igb driver does not support VLAN tagging or jumbo frames when in NetQueue mode. Disable NetQueue when using VLAN tagging or jumbo frames."
Did see some on ebay from Canada for pretty high prices.
BruceD
BruceD is offline
post #4 of 4 Old 12-13-2012, 02:43 PM - Thread Starter
BruceD's Avatar
Quoted: 12 Post(s)
Liked: 30
Bought the following and will see what happens.
Intel Pro/1000 PT Dual port GB Ethernet card EXP19402PT
BruceD
BruceD is offline
Reply Home Theater Computers
