Best way to discover missing episodes? What is the best way to generate a report or list of your current media ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 12-13-2012, 03:46 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Anyone ?
Mfusick is offline
post #2 of 28 Old 12-13-2012, 04:09 PM
joemoma's Avatar
If you organize your collection with sickbeard it will tell you what you're missing.
joemoma is offline
post #3 of 28 Old 12-13-2012, 06:15 PM
NorCalJason's Avatar
Liked: 30
+2 for sickbeard
NorCalJason is offline
post #4 of 28 Old 12-13-2012, 06:29 PM
hdkhang's Avatar
Does sickbeard know about episodes that are combined?
hdkhang is offline
post #5 of 28 Old 12-13-2012, 07:57 PM
joemoma's Avatar
Yes it's capable but if they're not named correctly it will fail.
joemoma is offline
post #6 of 28 Old 12-14-2012, 07:38 AM
scl23enn4m3's Avatar
What about Top Gear like season specials episodes?
scl23enn4m3 is offline
post #7 of 28 Old 12-14-2012, 07:53 AM
captain_video's Avatar
Quoted: 524 Post(s)
Liked: 341
I check epguides.com. They have complete listings of just about any show that's ever been aired along with any specials that are associated with each series. It's not an automated system, but it's an invaluable reference. I gave up archiving TV shows a long time ago since I just don't have the time to go back and watch an entire series twice. I barely have enough time to watch the shows I currently record.
captain_video is offline
post #8 of 28 Old 12-14-2012, 11:26 AM
jfpga's Avatar
using this atm
http://tvrename.com/
jfpga is offline
post #9 of 28 Old 12-14-2012, 11:40 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Is there a way to run a list of your media without media master ?
Mfusick is offline
post #10 of 28 Old 12-17-2012, 06:18 AM
Bonzai543's Avatar
Simple, but effective for Windows - put this line in a .bat file and place the .bat file in the root of your media files:
DIR /B /O:N /S > ListMovies.txt
Bonzai543 is offline
post #11 of 28 Old 12-17-2012, 08:47 AM
ljo000's Avatar
Media Center Master can generate a missing episodes report.
ljo000 is offline
post #12 of 28 Old 12-18-2012, 06:15 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
In theory yes. But that POS crashes and usually my Firefox browser opens and says no media. It's buggy and doesn't work well.
I reinstalled windows to a new SSD array and tried it fresh again and same thing .
I'm certain it's the program. It doesn't like big libraries over LAN on mapped network drives.
Mfusick is offline
post #13 of 28 Old 12-18-2012, 06:16 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Explain this anyone ?
I'm interested .
Mfusick is offline
post #14 of 28 Old 12-18-2012, 07:43 AM
vladd's Avatar
Liked: 39
That command does a directory listing of the folders and files in the current directory and sub directories (/S), sorts them by name (/O:N) and then displays the result in bare format (/B) meaning no header information or summary. Instead of displaying it to the screen, you are sending the results to a text file ( > ListMovies.txt )
You can run the command from a command prompt or place it in a bat file as suggested.
vladd is offline
post #15 of 28 Old 12-18-2012, 07:50 AM
Zagor's Avatar
I'm interested .
If I may,
it's a simple directory listing of files contained in the current directory and sub-directories. The resulting file list is outputted to a text file called "listmovies.txt"
The command is DIR the others are switches telling the DIR command how to list the results.
/B = Uses bare format (no heading information or summary)
/O:N = List by files in sorted order (N= By Name)
/S= Displays files in specified directory and all subdirectories.
You can see this all DIR switches by opening up a CMD prompt and type DIR /? and press enter.
So after you run the batch file containing this command line, it will create a text file with the results. You can use notepad to open the text file and see all your files listed there. This only tells you whats there in the specified order. It will not tell you what is missing but you can deduce that on your own by just looking at what is there. Also you can run the command manually (without having to put it in a batch file) but you would have to type in a cmd prompt every time you wish to run it. By creating a batch file, you only need to double click it to run it anytime you wish.
Too late, vladd beat me to it.
Zagor is offline
post #16 of 28 Old 12-18-2012, 06:52 PM
ljo000's Avatar
Strange. It works for me very well over the network for a 500GB TV collection (57 shows in 425 series).
ljo000 is offline
post #17 of 28 Old 12-19-2012, 05:38 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
I'm about 5TB per folder
Mfusick is offline
post #18 of 28 Old 12-19-2012, 10:59 PM
psouza4's Avatar
I've got a fairly sizable collection myself using mapped network shares to manage with Media Center Master (obviously, I'm the developer) and can't say I'm sharing the same performance issues you are. I'd be happy to help you troubleshoot that over at the MCM Community Forums (and I would start with recommending you take a look at the recommended performance tweaks I wrote up at our wiki).
Peter Souza IV
Author of Media Center Master (MCM)
psouza4 is offline
post #19 of 28 Old 12-20-2012, 07:00 AM
ljo000's Avatar
Given the amount of regular movies and TV series, I have to ask... what is the 1 Adult Title?
ljo000 is offline
post #20 of 28 Old 12-20-2012, 09:13 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
I really like the program. I'm a registered paid user.
I'll take you up on this offer. It's much appreciated.
Right now running the missing episodes report I get my Firefox browser opened saying no media. But it runs perfectly for fetching. I just reinstalled both my OS and mediacentermaster. No clue why missing episodes don't work.
Mfusick is offline
post #21 of 28 Old 12-20-2012, 11:11 AM
drealit's Avatar
I've been using TVRename for several years now (mentioned above). It works fantastic and I have it automatically renaming and copying my files as they download (it's all automated from start to finish unless something goes wrong).
drealit is offline
post #22 of 28 Old 12-20-2012, 11:48 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
I'm pretty satisfied with media center master when it's working properly. It's certainly worth the price. It's most powerful tool of its kind.
I use many if the premium features like renaming. I love how it names properly and will include the year and resolution in the name.
I did my whole collection like that.
I just wish the missing episodes was working.
I've used it before and it was great. Once it stopped working that's the only thing that cause me to ask and start this thread.
I plan to reinstall tonight and test again. If it don't work I guess I'll trouble shoot it.
Mfusick is offline
post #23 of 28 Old 12-20-2012, 05:03 PM
ljo000's Avatar
Have tried opening the report in a different browser?
ljo000 is offline
post #24 of 28 Old 12-20-2012, 07:52 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Yup. Tried that.
Mfusick is offline
post #25 of 28 Old 12-21-2012, 04:07 PM
psouza4's Avatar
For whatever reason, Hellbound: Hellraiser II (1988) is showing up as Adult in the Horror/Thriller genre. Looks like the MPAA rating was nixed on it. Refetched and it's no longer showing as adult. wink.gif
Peter Souza IV
psouza4 is offline
post #26 of 28 Old 12-21-2012, 04:12 PM
psouza4's Avatar
No problem!
Let me know what you turn up and I'll be watching the MCM forums for your post if you need any help getting it going.
Peter Souza IV
psouza4 is offline
post #27 of 28 Old 07-20-2013, 11:46 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Lol. I never noticed that.
Mfusick is offline
post #28 of 28 Old 07-20-2013, 11:46 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
No problem!
After re installing on a new machine it appears to be working so I just left it alone. Thanks again for the offer to help.
Mfusick is offline
Reply Home Theater Computers
