Atom Bay Trail - The next great HTPC chip? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 12-20-2012, 08:15 AM - Thread Starter
jeffkro's Avatar
How many of us are planning on bay trail for their next build?
Dx11
HDMI 1.4
quad core 2.1ghz
HD4000 based graphics
It sounds like it will be a fully capable HTPC while using almost no electricity.
Bay-Trail-T-3.jpg 116k .jpg file
jeffkro is offline
post #2 of 25 Old 12-20-2012, 08:39 AM
sumrtym's Avatar
Only 4 execution units vs 16 for graphics as compared to Ivy Bridge.
sumrtym is offline
post #3 of 25 Old 12-20-2012, 09:05 AM - Thread Starter
jeffkro's Avatar
Don't get me wrong, ivy bridge is faster. Its just that bay trail should do everything HTPC at significantly lower power consumption and probably easily allow for passive cooling. CULV ivy bridge could probably do the same thing but you are talking $200 just for the chip and not really available to system builders. The lower execution units will rule out people that use MadVR I'm assuming.
jeffkro is offline
post #4 of 25 Old 12-20-2012, 10:05 AM
CSMR's Avatar
I am planning to. I am hoping to see tiny systems based on this.
The first worthwhile Atom chip IMO, with Intel using its latest graphics and process technology, unlike Atoms of the past.
CSMR is offline
post #5 of 25 Old 12-20-2012, 01:53 PM - Thread Starter
jeffkro's Avatar
I personally want an itx board with one pcie slot and desktop ram, I'm mostly looking for a low Watt system to replace my zacate setup. But yeah a prebuilt mini system might be nice for an extender/client.
jeffkro is offline
post #6 of 25 Old 12-20-2012, 09:17 PM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
Since when is Atom the next great anything?
almostinsane is offline
post #7 of 25 Old 12-20-2012, 10:34 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
I always try the newest generation Atom. I've built quite a few fully passive Atom PCs for music servers and nettop/kids' school PCs. It's always a bit weird turning one on though and hearing absolutely nothing. I can use the smallest case I have (197x197x80mm) with no worries about fan noise, heat, etc.
If it's really going to be a 22nm quad-core with 60-70% CPU improvement and some kind of Intel HD graphics or derivative it might finally be what we want.
StardogChampion is offline
post #8 of 25 Old 12-20-2012, 10:43 PM
dksc318's Avatar
Did you use the DN2800MT? How was it as a streaming device?
dksc318 is offline
post #9 of 25 Old 12-21-2012, 07:01 AM
Quoted: 93 Post(s)
Liked: 160
I tried the D2700DC board. It did everything well except it would not play Netflix HD. Also, in Windows I had to turn Aero effects off to get rid of an annoying effect seen when min/max'ing windows. What was strange about Netflix HD is that it was stuttering and freezing but it the CPU wasn't max'd out so I suspect it was more a GPU driver issue.
The GPU driver issues are what kill this platform. There is absolutely no support for the onboard video in Linux (would have made a great passive OpenELEC system if there were support) and the GPU driver in Windows is 32-bit only so the whole install ends up being 32-bit.
So, I've only used the D2700DC then for passive nettop and music server applications. I have been looking at getting in some D2550/GT610M motherboards but they have fans (in my experience these fans are noisy/breakdown and are hard to replace) and they're comparatively expensive.
Ideally, there'll be a passive Bay Trail board and it'll have the regular Intel HD graphics or some derivative that uses the same Intel drivers as the other GPUs.
post #10 of 25 Old 12-21-2012, 08:21 AM - Thread Starter
jeffkro's Avatar
Yup, netflix HD, hulu HD, youtube HD is the main reason atom and zacate have not been acceptable HTPC's. Streaming is one of the major uses of HTPC's. I have an old athlon II system sitting around that I'm actually thinking about going back to for my secondary HTPC, my zacate system just doesn't cut it.
jeffkro is offline
post #11 of 25 Old 12-21-2012, 08:24 AM - Thread Starter
jeffkro's Avatar
I think 60-70% cpu performance is a slam dunk, twice the number of cores and a faster clock speed. So it should almost get there without any architecture improvements.
jeffkro is offline
post #12 of 25 Old 12-21-2012, 06:29 PM
dksc318's Avatar
..... What was strange about Netflix HD is that it was stuttering and freezing but it the CPU wasn't max'd out so I suspect it was more a GPU driver issue.
Intel must have realized fixing the Atom video driver would impact sales of higher end Sandybidge platforms.
dksc318 is offline
post #13 of 25 Old 12-21-2012, 08:45 PM
Quoted: 93 Post(s)
Liked: 160
post #14 of 25 Old 12-22-2012, 05:28 AM
LexInVA's Avatar
Quoted: 656 Post(s)
Liked: 269
They have already said as much. I welcome the new Atom and I am looking forward to it for tablets though I think the NUC setups that Intel is pushing will effectively kill the new Atom as an HTPC platform given the superior performance of the current Ivy Bridge hardware and the Haswell NUC design that is coming out in several months.
LexInVA is offline
post #15 of 25 Old 12-22-2012, 11:48 AM
Quoted: 93 Post(s)
Liked: 160
I was thinking that the mobile desktop stuff could kill Atom too but the price of the processor they're using in the NUC is $225 alone. That makes it hard for anyone but Intel to sell them at a decent price. As long as they're that price and you can get an Atom board for $80, there'll be a place for Atom. Though, now that I say that the $85 Celeron 847 boards I've tried are really nice, have the Intel 2000 HD GPU and can run Netflix HD. I just wish someone would make a passive one. Atom is 18W TDP and the Celeron 847 is 17W TDP so there's no reason it cannot have a huge passive heatsink on it instead of these noisy 40mm fans.
post #16 of 25 Old 12-22-2012, 01:05 PM
dksc318's Avatar
Atom will move to compete with ARM. They will get more cores and lower power.
dksc318 is offline
post #17 of 25 Old 10-23-2013, 11:46 AM
pittsoccer33's Avatar
Quoted: 650 Post(s)
Liked: 432
Any news in this space? I saw a few Windows 8 convertibles that will be using Bay Trail. Just wondered if anyone saw what kind of video playback capability is has.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #18 of 25 Old 10-23-2013, 12:52 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
http://www.anandtech.com/show/7314/intel-baytrail-preview-intel-atom-z3770-tested
techmattr is offline
post #19 of 25 Old 10-23-2013, 02:02 PM
LexInVA's Avatar
Quoted: 656 Post(s)
Liked: 269
Now if only someone would make a decent-sized 1080P Bay Trail tablet with 16:9/16:10 aspect ratio and an SD card slot and a USB port.
LexInVA is offline
post #20 of 25 Old 10-24-2013, 07:51 AM
Quoted: 93 Post(s)
Liked: 160
Here are three new ECS Bay Trail-D motherboards. No news on price/availability.
http://www.anandtech.com/show/7453/ecs-reveals-bay-traild-miniitx-line
post #21 of 25 Old 10-24-2013, 11:53 AM
Spec4's Avatar
Liked: 24
Exhibit A (my favorite)
Exhibit B
Exhibit C
Spec4 is offline
post #22 of 25 Old 10-24-2013, 12:39 PM
Quoted: 93 Post(s)
Liked: 160
I am interested in what happens with the HDMI hooked to the tablet. Can you extend or duplicate the displays? With full Windows 8.1 running I am assuming you can add WMC, setup Live TV through networked cable card, etc. and basically make the tablet an HTPC. It would be interesting to sit the tablet on a dock and use it as a touchscreen HTPC. I wonder what to use as a remote. USB IR receiver? Network remote control?
post #23 of 25 Old 10-25-2013, 10:27 AM
CSMR's Avatar
These are legacy designs for interfacing with old equipment (via COM, PS/2, VGA).
Intel will have a NUC in Q1 2014:
http://techreport.com/news/25373/report-bay-trail-nuc-to-cost-139-support-2-5-inch-drives
I hope the wifi card can be replaced with mSATA for an SSD boot drive.
CSMR is offline
post #24 of 25 Old 10-26-2013, 08:51 AM
Jeff Krogue's Avatar
Bummer they went with the dual core bay trail for the NUC.  That might make it under powered for handling Netflix HD.
Jeff Krogue is offline
post #25 of 25 Old 11-04-2013, 11:58 AM
Quoted: 93 Post(s)
Liked: 160
I am not sure how that matters. They also have HDMI and SATA connections, making them suitable for HTPC use as well.
Reply Home Theater Computers
