Help Please Have a event error.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-21-2012, 07:03 AM - Thread Starter
Rew452's Avatar
Quoted: 107 Post(s)
Liked: 64
I have a win7 event error which is in reference to a vidio directory...
The description for Event ID 0 from source Application cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
ProcessWorkItem
M:\Video\2012 (2009)
Nullable object must have a value.
the message resource is present but the message is not found in the string/message table
I have searched web but found nothing. Does anyone recognize having this error and or found a cure for it??
Thanks for your help!
Rew
Rew
Vizio P75-C1 | OPPO UDP-203 | Samsung UBD-K8500
Denon AVR-x5200w | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is offline
post #2 of 3 Old 12-22-2012, 12:33 PM
kegobeer's Avatar
What application is causing the error? If you don't know, then look at the current running processes and compare them to the event log entries. Speaking of which, how often do you get these event log entries? Is it all the time (every x seconds/minutes/etc)? Do you know when this started? Have you checked to see if you uninstalled or relocated an application that is attempting to access that particular directory?
kegobeer is offline
post #3 of 3 Old 12-22-2012, 01:45 PM - Thread Starter
Rew452's Avatar
Quoted: 107 Post(s)
Liked: 64
That's the big question. Need to find out then maybe I can clear it.
Rew
Rew
Rew452 is offline
Reply Home Theater Computers
