dual LAN. WTF is the purpose ???? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 12-22-2012, 09:06 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I have dual lan on my motherboard. One is Intel.
I have dual LAN on my server. One is an Intel NIC card. Other is stock Asrock.
Does it make sense to connect the server and PC with a switch- and run internet to each PC from the router ???
Or not ?
Currently- I have my modem to a router- the router to a switch- and all clients plugged into the gigabit switch.
That still the best way to do it ?
Mfusick is offline
post #2 of 20 Old 12-22-2012, 09:57 AM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Right now, you only have a single LAN, so, no benefit. Now, you could go crazy with LAN configurations....for e.g. seperate all your media traffic on one LAN, internet on the other...or run a teamed adapter setup, or run a VPN on the second NIC or...Well, you get the idea.
kapone is offline
post #3 of 20 Old 12-22-2012, 10:55 AM
dksc318's Avatar
Both my servers have dual LAN. One is a commercial (vs desktop) board with two on MB intel NICs. I can use "teaming" function in Windows7. The new server box I just brought up has a PCI Ralink NIC plus the MB NIC and I didn't see teaming function available. Still looking at how to do teaming.
dksc318 is offline
post #4 of 20 Old 12-22-2012, 11:12 AM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Teaming doesn't really offer you anything unless your routers and switches support Link Aggregation
Andy_Steb is offline
post #5 of 20 Old 12-22-2012, 11:32 AM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
And even then, it's really useful only on the server side, where you may have multiple clients connecting to it. A single session on the client side will always be limited to the speed of a single NIC.
kapone is offline
post #6 of 20 Old 12-22-2012, 11:38 AM
mslide's Avatar
You most likely have no reason to use both NICs. Some reasons why one might:
1) Link aggregation - LACP: Link the 2 ports together so they act as one really fast connection. Your switch has to support and be configured for this and that's typically only found on more expensive managed switches. This only makes sense when you have clients who together can exceed the bandwidth of one 1GbE port. Unless you had a bunch of computers pounding your server all the time and 1GbE connection really isn't fast enough, this doesn't make sense for someone at home. Corporations and data centers? Used all the time.
2) Link aggregation - Failover: Instead of linking them to act as one port, the second one takes over if the first one fails. Useful in enterprise situations where you can't tolerate a NIC failure. For home users, it usually doesn't matter.
3) You need to connect to 2 different networks. Again, not typical in a home environment but common in corporations and data centers.
4) You're running virtual machines and you don't want them to share a single physical NIC. You might, instead, want them to have their own physical nics.
Just leave the second one disconnected. Honestly, I'm surprised I see so many consumer grade motherboards with 2 NICs. It's just so rare in a home environment.
mslide is offline
post #7 of 20 Old 12-22-2012, 12:44 PM
dksc318's Avatar
I have 3 HTPCs that can access the server at the same time. In any case, the server board has this function and I'm using it. This is a BCM RX67Q made for commercial use. It doesn't have the dual NIC issue with intel boards and WHS2011.
From what I can see, when streaming, the HTPC doesn't exceed bandwidth of a N WiFi link, which is less than 300Mb. So even with 3 HTPCs, they will not exceed 1Gb bandwidth in my network.
dksc318 is offline
post #8 of 20 Old 12-22-2012, 01:51 PM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Nothing you are "streaming" from your server exceeds 50mbps. smile.gif That's the max bitrate for a bluray, everything else is lower.
File copy is a different issue, but streaming...you'll be fine with a gigabit connection for up to 15 clients, if not more.
kapone is offline
post #9 of 20 Old 12-22-2012, 06:00 PM
erickotz's Avatar
Liked: 30
The real answer: so the marketing people have a bullet point to check off
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #10 of 20 Old 12-22-2012, 11:17 PM
Tong Chia's Avatar
Dual Lans are a marketing gimmick for HTPC
That said, I am experimenting with LACP between the server and switch and in between the switches to reduce network latency
My HDHomerun is very finicky and it uses the unreliable datagram protocol to send video to the server running the PVR. it starts tossing frames when there is the slightest hint of congestion. Lately it became worse as my Macs got more aggressive with the timemachine backups, this caused occasional spikes in network latency because of backup traffic. LACP aggregated between the switches and the server seems to help, the frame drops have disappeared. I might make this permanent.
Tong Chia is offline
post #11 of 20 Old 12-23-2012, 06:00 AM
jmallory's Avatar
I have dual NICs on my EVGA motherboard in my HTPC. One goes to the House VLAN on my "core" switch, the other is connected to a small VLAN for my HDHomerun. Probably overkill but does work well.
-- Jim
jmallory is offline
post #12 of 20 Old 12-23-2012, 08:44 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
If be interested in a direct link from my workstation to my server that's fast for copy paste of movie folders.
Both machines gave dual LAN and each one intel.
Worth the trouble ? My drives write and read around 130mb speeds but my network always seems 90mb about.
Mfusick is offline
post #13 of 20 Old 12-23-2012, 09:18 AM
vladd's Avatar
Liked: 39
Yup, I like to isolate the HDHomeRun traffic to the server as well since none of my client machines require direct access to them. Otherwise watching live TV on a client would result in double network traffic (HDHR -> server and server -> client). I run a separate switch for them instead of VLANs though.
vladd is offline
post #14 of 20 Old 12-23-2012, 10:29 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
vladd did you ever test Sata2 vs sata 3 SSD raid ?
Mfusick is offline
post #15 of 20 Old 12-23-2012, 10:40 AM
vladd's Avatar
Liked: 39
Not yet. Since Thanksgiving, I pretty much blew my Christmas budget on the wife and kids and had to dip into my electronics budget. biggrin.gif
I'm hoping to get new equiptment after the New Year though.
vladd is offline
post #16 of 20 Old 12-23-2012, 01:41 PM
Tong Chia's Avatar
The easiest thing to do is to turn on 9K Jumbo frames on the client and server, it gives me 125MBytes/s on my setup read/write to any client.
If you have already done so, your server software may be holding you back. I suggest you consider Win8 server and Win8 for your workstation, Microsoft improved their SMB file sharing protocol to support native aggregation of LAN links and remote DMA. The former can increase your thruput on multi NICs and the latter halves the network latency, your NIC and client must suport it. Win8 is still pretty new, there are a couple of bumps with it as a HTPC.
post #17 of 20 Old 12-23-2012, 03:22 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Nope I have not adjusted anything ... I'll do a google search and check it out. Thanks.
Mfusick is offline
post #18 of 20 Old 12-28-2012, 02:18 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I have WHS2011 and Windows7 x64 PRO.
What should I expect. The run of cable between them is only 6 feet. I have an Asus Gigabit Switch connecting them .
Mfusick is offline
post #19 of 20 Old 12-28-2012, 04:04 PM
Tong Chia's Avatar
If it SSD->SSD you should see 125Mbytes/s which is the Max for GigE if you have a decent nic.
The numbers I mentioned earlier was from my i7950/W7Pro64bit coming off a 2TB Caviar Black to/from my ZFS box
post #20 of 20 Old 12-29-2012, 08:16 AM
zicoz's Avatar
For a server: Either improved performance or improved reliability
For a HTPC: Essentially useless, but it does improve reliability
Besides, you won't have to get a PCI-E NIC or a new motherboard if the NIC you're using dies.
zicoz is offline
Reply Home Theater Computers
