Is this enough for a htpc? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 12-22-2012, 08:55 AM - Thread Starter
kwed's Avatar
I am looking to dump directv and run my tv through Windows Media Center (live channels & dvr). I have built this HP slim tower to lay in my media center, but am concerned about my graphics card. I want to know if it is enough to run a dvr through it.
HP Pavilion Slimline s5-1400t Desktop PC
C1T84AV#ABA
Windows 8 64
2nd Generation Intel(R) Core(TM) i3-2130 dual-core processor [3.4GHz S, 3MB Shared Cache]
4GB DDR3-1333MHz SDRAM [1 DIMM]
1TB 7200 rpm SATA hard drive
Microsoft Office Trial
No additional Security Software
No TV Tuner
1GB AMD Radeon HD 7450 [DVI, HDMI, VGA adapter]
SuperMulti DVD Burner
Wireless-N LAN card (1x1)
6-in-1 memory card reader, 2 USB 3.0, headphone
Beats Audio (tm) -- integrated studio quality sound
HP USB keyboard and optical mouse
I will be buying a usb tv tuner. Good enough? Thanks
kwed is offline
post #2 of 15 Old 12-22-2012, 08:56 AM - Thread Starter
kwed's Avatar
Also as a side note, what kind of graphics card would I need to run this? Are integrated graphic cards enough?
kwed is offline
post #3 of 15 Old 12-22-2012, 10:30 AM
duff99's Avatar
It should work fine. The integrated graphics would probably work, but it's got a capable add in card already.
duff99 is offline
post #4 of 15 Old 12-22-2012, 11:22 AM
Postmoderndesign's Avatar
Quoted: 328 Post(s)
Liked: 149
You might want to look at one of the Silicon Dust HDHomerun ethernet TV tuners and a Channel Master antenna suggested for your location at antennaweb or TVfool. I have been pleased with the HDHR3-US for over the air ATSC TV. There is also an expansion card tuner that gets a lot of positive reviews.
I could not see where you are planning to get you TV programming from.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #5 of 15 Old 12-22-2012, 01:26 PM - Thread Starter
kwed's Avatar
I have an antenna with a pre-amp in the attic. I am getting 80 channels, nbc is a little blurry. I am about 25-30 miles from the towers. I thought windows media center has a channel guide built in it, like my google tv.
kwed is offline
post #6 of 15 Old 12-22-2012, 01:48 PM
Quoted: 328 Post(s)
Liked: 149
Yes, 7MC has a channel guide built in.
post #7 of 15 Old 12-22-2012, 05:19 PM - Thread Starter
kwed's Avatar
Thanks alot. One last question, would this computer be good enough to stream live tv through a usb tuner?
Trying to save about a grand a year and I want to make sure this will do the job. Plus need the wife to be able to operate the tv easily and I have read WMC is the easiesst ui to learn.
kwed is offline
post #8 of 15 Old 12-22-2012, 05:30 PM
ZenithPete's Avatar
It should be. However, I would highly recommend installing windows on an SSD drive. If you plan on using windows media center this makes a noticeable difference as far as how fast the guide loads and you can scroll through it and the overall responsiveness of using an htpc as a dvr. You should have room for an SSD and larger regular or external hard drive for recordings.
ZenithPete is offline
post #9 of 15 Old 12-27-2012, 09:40 PM - Thread Starter
kwed's Avatar
A little update, I went ahead and bought the Hauppauhe 2250 dual tuner card and I'll install that versus usb stick. Would I need to pirchase windows 8 to put it on a SSD? Great suggestion about read time.
kwed is offline
post #10 of 15 Old 12-27-2012, 10:23 PM
Tiddles88's Avatar
Liked: 24
Not worth buying. The extra GPU is redundant, the i3 is good enough. Also that i3 is Sandy Bridge, its been replaced by the i3 3220/3225 which I'd get for the upgraded GPU. You are also missing an SSD.
Tiddles88 is offline
post #11 of 15 Old 12-28-2012, 08:00 AM - Thread Starter
kwed's Avatar
i was going to add a SSD and put windows 8 on it for quicker boot time and other things, but keep the TB hard drive for shows and videos.
kwed is offline
post #12 of 15 Old 12-28-2012, 10:59 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
SSD?
Life's not worth living without one.
Mfusick is offline
post #13 of 15 Old 12-28-2012, 03:00 PM - Thread Starter
kwed's Avatar
quick question. I there a site or step by step instructions on how to install Windows 8 pro onto an ssd drive, with Windows 8 on the main hard drive? I will add the ssd later, but want everything to boot from it.
kwed is offline
post #14 of 15 Old 12-29-2012, 07:48 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
just set bios to ACHI (default on new motherboards so just check) and install from disc.
You don't need to do anything else. Windows set up screens walk you through it.
Assassin does have a guide that covers that.
Mfusick is offline
post #15 of 15 Old 12-29-2012, 08:08 AM - Thread Starter
kwed's Avatar
so i would need the windows 8 disc? And what would I do to the hdd that has windows 8 on it already? Just reformat it?
kwed is offline
Reply Home Theater Computers
