Windows 8 and wmc 32 or 64 bit does it matter? - AVS Forum | Home Theater Discussions And Reviews
Old 12-24-2012, 08:14 AM - Thread Starter
etrin's Avatar
Quoted: 25 Post(s)
Mainly I am just curious if it really matters with windows 7 or 8 if you use a 32 bit or 64 bit os?
etrin is offline
Old 12-24-2012, 08:34 AM
tman247's Avatar
Quoted: 56 Post(s)
Liked: 50
I would say these days it doesn't really matter. There's a gradual move to x64 (many were surprised Windows 8 had a 32-bit version at all), and 64-bit driver support has now matured enough that there shouldn't be any issues. My Windows 7 HTPC is still x86, but if I was to rebuild again at the moment, I'd probably go x64.
tman247 is offline
Old 12-24-2012, 08:49 AM
Postmoderndesign's Avatar
Quoted: 218 Post(s)
Liked: 85
I just rebuilt my computer and installed Windows 7 64 bit. Windows 7 sets up two program files directories, one for 64 bit programs and one for 32 bit programs. I don't know about Windows 8.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
Old 12-24-2012, 09:27 AM
Mac25's Avatar
Quoted: 14 Post(s)
X64 if using more than 4 gb memory, other wise no real diff.
Mac25 is offline
Old 12-24-2012, 09:31 AM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
Ceton recommends 4GB of ram, so if you are using their card, it may make sense to go x64. I didn't see any difference between running x86 with 2GB vs x64 with 4GB in terms of recording or watching live TV.
Carty Custom Builders, LLC
ncarty97 is offline
Old 12-25-2012, 11:47 AM
onlysublime's Avatar
Quoted: 770 Post(s)
Liked: 1204
the software has to be native x64 code to see improvements and it's only a 10-15% improvement. otherwise, it just let's you use more of your RAM. With x86 (32-bit), you're limited to 4GB of address space. that means a TOTAL of 4 GB for everything you own. That means if you have a 1 GB graphics card and 4 GB of RAM, you'll only see 3 GB of RAM because 32-bit can only recognize 4 GB total. There are ways around the 32-bit limitation (read: PAE) but it's just easier and better to go to a 64-bit OS.
then you factor how software factors into this address space and 32-bit because a real problem. On 32-bit Windows, in normal configurations, each program only has a usable address space of about 2GB, half of the total memory that can be addressed with 32-bit addresses. This means that the amount of RAM that the program can manipulate directly is limited to 2GB. If the program needs to work on a larger chunk of data, it has to move that data in and out of RAM a piece at a time, usually storing it on disk when it's not in RAM. This 2GB limit is regardless of the amount of physical memory installed; if you run multiple programs, they each get a 2GB block of their own, so they can use many gigabytes in total, but any individual program can't readily break through this limit.
another thing is 64-bit code is more secure. there's malicious code that's designed to fill up the address space and execute. that's many times easier to fill up the space of a 32-bit system due to the very very small address space. unfortunately, as long as you're running 32-bit software on your system, as long as the exploit can take advantage of that particular software, you have a vulnerability there. but it's a 1-to-1 exploit. so if some malware guy writes something to target 32-bit Adobe Acrobat Reader but you don't have that program, it doesn't matter.
most software is still 32-bit, including most TV software. If you move on to more complicated software like video editors, many of them like Adobe Premiere ONLY have a 64-bit version.
there's really no point in installing a 32-bit OS at this point, especially since the 64-bit version can run 32-bit software. the only time you need a 32-bit OS is if there's a particular hardware device you own that has no driver in the 64-bit OS and it's such a legacy device that the company has not made a driver for it. that said, a lot of old devices still have drivers that'll work.
onlysublime is online now
Old 12-25-2012, 03:26 PM - Thread Starter
etrin's Avatar
Quoted: 25 Post(s)
thank you for the replies.
I know when I built my first htpc it as DO NOT go 64 bit because all the software was 32 bit and only tested on 32 bit I guess or it might be because win7 had just come out and people thought it was like xp and 64 bit was iffy at best.
Anyway I just build my new one and I have win8 64 bit. Was going to put it on a new desktop but I decided to put it on the htpc. The only old thing I have in it is an avermedia Hd duet so I might be cussing tomorrow LOL
etrin is offline
Old 12-25-2012, 03:46 PM
rdunnill's Avatar
I've been using 64-bit for years, and never did have a problem that I could trace to it. Now that all new CPUs are 64-bit and 2 x 4gb memory stick pairs can be had for $40 or less, I don't see a point in using 32-bit for a new build.
Blu-ray: 50+
HD-DVD: 23
DVD: 600+ and lost count
rdunnill is offline
Old 12-25-2012, 04:03 PM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
At this point I think you'll encounter more issues going with 32-bit, mainly upgrading the ram of course.
lockdown571 is offline
Old 12-25-2012, 11:56 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
FWIW, I'm using a pair of AverMedia Duet cards with Windows 7 64 bit & WMC7 and they are working great.
Mike99 is offline
