Media Servers, flexraid and antivirus - AVS Forum | Home Theater Discussions And Reviews
post #1 of 65 Old 12-25-2012, 08:25 AM - Thread Starter
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
I just redid my htpc/server config and will be setting up flexraid for pooling with 1 parity drive.
Do you guys run antivirus on the server? I will be using Windows7Pro 64bit. Windows Defender will be on, but I also use NOD AV by ESET. Do you guys run anything, or advise against it? I dont know how it would affect flexraid parity, validiation, verification etc if at all.
aliaskary77 is offline
post #2 of 65 Old 12-26-2012, 02:20 AM
flocko's Avatar
I use Microsoft Security Essentials on my server running FR . No issues at all . I would not use Defender if your using third party avs as conflicts could occur in the os
flocko is offline
post #3 of 65 Old 12-26-2012, 06:23 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 56
i thought defender was renamed to security essentials. i must be wrong.
on the current laptop its seems to have worked hand in hand with nod.
but since the server will be for backup and media storage, i may not need av on the server as everything will be filtered through the desktop and its antivirus.
thanks.
post #4 of 65 Old 12-26-2012, 07:24 AM
Mac25's Avatar
Quoted: 14 Post(s)
mse for seven and earlier os, in win 8 it is named defender, both appear the same, I run win 8 for server duties and just left defender alone, shouldn't need for server duties imo.
Mac25 is offline
post #5 of 65 Old 12-26-2012, 07:51 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
+1 for FREE MS Security Essentials. There is a certain version that works on WHS2011.
Mfusick is offline
post #6 of 65 Old 12-26-2012, 10:20 AM
Puwaha's Avatar
Liked: 35
You don't use a server for day to day web browsing or email so there is no need for AV software on it.
Puwaha is offline
post #7 of 65 Old 12-26-2012, 11:25 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
+1.
I run Security Essentials on mine only because it's free and easy. I am not sure I really need it though.
Mfusick is offline
post #8 of 65 Old 07-30-2013, 10:56 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
So is it really necessary or not to have the antivirus on whs? I just got a virus in my pc and am really worried that it might have gone to my server because I logged into it through my pc. Any thoughts?
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #9 of 65 Old 07-30-2013, 12:34 PM
Dark_Slayer's Avatar
Quoted: 721 Post(s)
Liked: 448
I used to run all my computers without av software prior to MSE. While I don't think it's necessary, it doesn't hurt anything plus it's free.
My curiosity is really focused on how you determined that you got a virus. What behavior was exhibited by the pc?
Dark_Slayer is offline
post #10 of 65 Old 07-30-2013, 12:47 PM
g725s's Avatar
Originally Posted by Mfusick View Post
+1.
MSE with WHS 2011?
Which version works with WHS 2011 without issues?
g725s is offline
post #11 of 65 Old 07-30-2013, 12:52 PM
Quoted: 721 Post(s)
Liked: 448
Originally Posted by g725s View Post
MSE with WHS 2011?
http://www.avforums.com/forums/17953649-post2.html
bryansj and Pain Infliction like this.
post #12 of 65 Old 07-30-2013, 12:56 PM
Quoted: 978 Post(s)
Liked: 506
I got that snap.do virus and it will not let me uninstall IE and it is also showing that my MSE is functioning correctly but it is secretly disabled. Sounds more like a Trojan to me. I am just going to put in a bigger hard drive and redo my pc because I'm not going to take any chances. I already have all my data backed up so no worries. Just need to install all my programs.
Do you think my server is in jeopardy?
post #13 of 65 Old 07-30-2013, 01:02 PM
Quoted: 978 Post(s)
Liked: 506
Also, MSE seems like it would take a long time to scan all of the hard drives. Is that an issue?
Mfusick likes this.
post #14 of 65 Old 07-30-2013, 01:05 PM
bryansj's Avatar
Quoted: 1333 Post(s)
Liked: 625
Makes me wonder if this works with WSE2012 since Win 8 has a version of MSE built-in.
bryansj is online now
post #15 of 65 Old 07-30-2013, 02:11 PM
Quoted: 721 Post(s)
Liked: 448
I don't believe so unless anything has changed in the last few months due to the inability to install mse in W8. I've only heard of FCS working, but I've never used or tried it nor do I even have a WSE2012 server http://www.tinkertry.com/antivirus4ws2012e/
Mfusick likes this.
post #16 of 65 Old 07-30-2013, 05:42 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Just install the FREE MS SECURITY ESSENTIALS.
It's easy. It's free. It's what I use.
I use it on mine- that way your server is protected. It's like insurance. Hopefully you won't need it or need to use it, but if you do you will be glad you have it.
just let it run and go to bed or something. Check the next day. It's not a race.
I would not use your server until you get a deep scan completed and an antivirus installed and working. That would be a safe route to take.
You will probably be ok- but running a deep virus scan would / should ease your fears more than my saying so biggrin.gif
If you need it,
https://www.dropbox.com/s/4cfrgz6a4f6mdfj/Microsoft%20Security%20Essentials%20works%20with%20WHS2011.exe
There you Go: ^^^^^^^
This is the version of MS SECURITY ESSENTIALS that I use that will install and work perfectly on WHS2011
I originally discovered this from Assassin when he was building the Goliath server. He linked it in his server guides (which are good btw)
This is from my personal drop box so it's likely this link won't work forever (when I remove it it will stop working)
I will leave it up for a while. PM me if you really need it again.
BTW- Thanks for the kind comments on your theater build thread biggrin.gif Happy to help. Glad you got WHS installed to your SSD after much fuss eek.gif
Pain Infliction likes this.
Mfusick is offline
post #17 of 65 Old 07-30-2013, 07:35 PM
itznfb's Avatar
Liked: 58
Antivirus software... bah. What a waste. I haven't installed Antivirus in years. All of my network traffic is local and anything I do online is done through DamnSmall on VirtualBox. smile.gif
Running Windows Home Server 2011 Evil Abandoned Edition
itznfb is offline
post #18 of 65 Old 07-30-2013, 07:48 PM
robnix's Avatar
Quoted: 740 Post(s)
Liked: 549
You're awesome.
Looky here!
robnix is online now
post #19 of 65 Old 07-30-2013, 07:49 PM
amarshonarbangla's Avatar
Quoted: 30 Post(s)
Liked: 43
I wouldn't use MSE.
amarshonarbangla is offline
post #20 of 65 Old 07-30-2013, 08:00 PM
robnix's Avatar
Quoted: 740 Post(s)
Liked: 549
Originally Posted by amarshonarbangla View Post
I wouldn't use MSE.
Why?
Looky here!
post #21 of 65 Old 07-30-2013, 09:26 PM
Quoted: 30 Post(s)
Liked: 43
Originally Posted by robnix View Post
Why?
Protection score: 0
http://www.av-test.org/no_cache/en/tests/test-reports/?tx_avtestreports_pi1%5Breport_no%5D=132335
MSE has failed to receive the certification multiple times in the past
http://www.tomshardware.com/news/AV-TEST-Certification-Security-Essentials-Double-Failure-0-Day,20524.html
post #22 of 65 Old 07-31-2013, 04:44 AM
itznfb's Avatar
Liked: 58
You're awesome.
I'm experienced. Part of my job is testing anti virus software and they are all pretty terrible to be honest. Using a browsing VM is infinitely more secure then relying on AV software. amarshonarbangla is also correct that MSE is one of the worst AV solutions available. It's fairly decent at removing malware but almost incapable of prevention.
itznfb is offline
post #23 of 65 Old 07-31-2013, 05:19 AM
Rew452's Avatar
Quoted: 113 Post(s)
Liked: 65
I would suggest looking at Vipre. It runs on all versions of windows including WHS.
If look around you can find good deals on multi user versions.
Came accrossed it a number of years ago when Norton blew me out of the water on a update. Let alone ate up system resources.
Would not say perfect but does the job at decent price and little if any impact on system performance.
Cheers
Rew
Rew
Vizio P75-C1 | OPPO UDP-203 | Samsung UBD-K8500
Denon AVR-X4300H00 | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is offline
post #24 of 65 Old 07-31-2013, 05:42 AM
Quoted: 978 Post(s)
Liked: 506
What is VM?
post #25 of 65 Old 07-31-2013, 05:47 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Virtual machine
Mfusick is offline
post #26 of 65 Old 07-31-2013, 05:58 AM
Quoted: 978 Post(s)
Liked: 506
Oh man! Another thing for me to look into. So is this a separate computer with a different OS that you browse with and your computers are connected to it via network??
post #27 of 65 Old 07-31-2013, 06:07 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Yes. Virtually.
You install an operating system and make a machine that is virtual and it runs inside your server. You pass thru hardware to the virtual machine.
If you get infected, it doesn't really hurt your real machine. Like running an OS install inside an OS install.
Don't waste your time. These guys are operating in a territory you don't want to go. You almost don't need anti virus on a server- so just install free ms security essentials and be done.
You'll likely not need it. I never have.
But I don't download or browse on my server.
Mfusick is offline
post #28 of 65 Old 07-31-2013, 06:38 AM
itznfb's Avatar
Liked: 58
Yes. Virtually.
Best practice is to never browse on a server. Though it's understandable that many home user's may only have one computer that also acts as their server. Which is why browsing through a dedicated browsing VM is ideal. As I said I use DamnSmall but someone sent me a link to Chromium Browser VM which I'm going to start looking into. What's nice with Virtual Box is that you can launch a seamless window so the browser running in the VM actually looks like it's just a browser you opened on your local machine.
itznfb is offline
post #29 of 65 Old 07-31-2013, 06:44 AM
Quoted: 978 Post(s)
Liked: 506
Ok....say my computer gets infected and I transfer media files to my server. Will my server be in risk of getting the same virus or trojan or anything at that point?
post #30 of 65 Old 07-31-2013, 06:46 AM
itznfb's Avatar
Liked: 58
If you transfer an infected file yes. It would be no different than the originating infection on your first machine.
itznfb is offline
Reply Home Theater Computers
