HTPC Hardware check - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-26-2012, 07:00 AM - Thread Starter
Stokess's Avatar
Hi all,
I currently use my HTPC as my only source of TV with the Ceton InfiniTV PCI-E w/ cable card from Mediacom. I haven't touched the hardware on this machine for awhile and wanted to see how I am sitting. Picture's are mostly smooth, maybe once an hour I'll see pixels as a picture lags for maybe a second and then its fine. No issues on watching recorded tv and fast forwarding or anything.
Also, I have the desire to see what 3D pictures can look like on my new TV which is capable, what kind of video card should I think about for that?
Here is the setup:
Intel i5 750 @ 2.67Ghz
HD 5670 512 MB
4GB Ram
1 TB 7200 RPM hard drive
I'm not worried about space because I have a 4 TB network attached storage (NAS), that I transfer movies over to.
Stokess is offline
post #2 of 4 Old 12-26-2012, 05:01 PM - Thread Starter
Stokess's Avatar
I downloaded Arcsoft Total Media Theatre 5.
I had everything set to 3D, but it wont give any sort of 3D picture with all settings on.
After doing some reading, it looks like I need at least a 6xxx series ATI if I go that route?
It seems like it revolves around HDMI 1.4 version and my stuff except my tv is 1.3.
Any advice here?
Stokess is offline
post #3 of 4 Old 12-28-2012, 01:05 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Any advice here?
I need to check, but I believe the AMD 5xxx series of cards do not fully support 3d, you need to go to the 6xxx series.
jdcrox is offline
post #4 of 4 Old 12-28-2012, 01:57 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
HD 5670 can output the HDMI 1.4a 3D video format (Frame packing). It does not support MVC decode, but i5-750 is fast enough to decode MVC.
Are you connecting the card directly to your TV? You can't insert a HDMI 1.3 AVR between the graphics card and TV.
renethx is offline
Reply Home Theater Computers
