BEST WAY TO FORMAT AND SET UP NEW HDD FOR MEDIA STORAGE ??? 3TB. WHAT FORMAT TYPE AND SECTOR SIZE ???? ADVICE? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 12-26-2012, 08:40 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
WHAT SAY YOU AVS?
Mfusick is offline
post #2 of 19 Old 12-26-2012, 10:06 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
For Media Storage I usually just go with the green drives (5400-5900 RPM). I have 15+ drives between the WD Green and Seagate LP drives. I also just picked up the new WD Red series to test out. I don't usually mess around with the format type or sectors
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #3 of 19 Old 12-26-2012, 10:55 AM
Puwaha's Avatar
Liked: 35
Format type? NTFS
Sector size? Minimum size I would use nowadays if 4096 bytes especially if you are using 4K drives and doubly so if you have a 512e drive. For video files only, a larger sector size can improve performance up to a point.
Puwaha is offline
post #4 of 19 Old 12-26-2012, 12:27 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Originally Posted by Puwaha View Post
Format type? NTFS
Just curious everyone's opinion on this.
Mfusick is offline
post #5 of 19 Old 12-28-2012, 02:19 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Anyone else have opinion
Mfusick is offline
post #6 of 19 Old 12-28-2012, 02:32 PM
Tiddles88's Avatar
Liked: 24
Stick it in and use disk management to format as defaults. One big fat 2.8TB GPT partition. I can't wait to get a 5TB+ HDD next year. Come on Western Digital!
Tiddles88 is offline
post #7 of 19 Old 12-28-2012, 03:01 PM
cybrsage's Avatar
Liked: 154
I do what TIddles does.
cybrsage is offline
post #8 of 19 Old 12-29-2012, 08:49 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I am seeing 4TB at the $179 mark. My local Costco had a WD for that last week I saw.
$150 for 4TB is a sweet spot for me.... I'll start buying 4TB at that price.
Mfusick is offline
post #9 of 19 Old 12-29-2012, 08:50 AM
Liked: 645
Yeah, stop yelling. Seriously man, you come off as half-deranged with these topics.
snappjay and rc05 like this.
slowbiscuit is offline
post #10 of 19 Old 12-29-2012, 08:52 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
huh?
Mfusick is offline
post #11 of 19 Old 12-29-2012, 10:08 AM
robnix's Avatar
Quoted: 661 Post(s)
Liked: 494
WHAT SAY YOU AVS?
For NTFS you mean allocation unit size, not sector size.
NTFS is the only option with Windows.
An allocation size of 8192 is what you want for drives dedicated to large media files. This will reduce fragmentation and seek times, you'll get better long term performance.
Looky here!
robnix is online now
post #12 of 19 Old 12-29-2012, 04:01 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
What is the default size ?
Mfusick is offline
post #13 of 19 Old 12-29-2012, 05:32 PM
robnix's Avatar
Quoted: 661 Post(s)
Liked: 494
4K up to 16TB.
Looky here!
post #14 of 19 Old 12-30-2012, 01:09 AM
dksc318's Avatar
I also do what Tiddles88 does for 3TB.
dksc318 is offline
post #15 of 19 Old 12-30-2012, 09:01 PM
erickotz's Avatar
Liked: 30
Disagree - stick with 4K clusters. While your logic is sound, cluster sizes other than 4K aren't well-tested. While Windows itself will handle it just fine (for the most part, I think even a few things in Windows didn't like it) any sort of 3rd-party utility that deals with files (AV, recovery, backup, cloning, encryption, etc) likely did not test with anything other than 4K clusters.
Up till about 18 months ago, I worked at MS, and among other things, supported storage for enterprise customers. We would generally tell them that non-4K clusters were a bad idea unless they had very specific reasons (I think SQL DB server was one of the few reasons), and even then, with caveats.
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #16 of 19 Old 12-31-2012, 09:26 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I'm not sure performance advantage is worth risk to go other than default. That was my general feeling when making this thread.
But I didn't know enough to actually know if I'm right or wrong. Hence I made the thread.
I'm curious if there is or isn't advantage to using a non default.
Mfusick is offline
post #17 of 19 Old 12-31-2012, 10:43 AM
erickotz's Avatar
Liked: 30
My personal media storage array (something like 10TB - I don't remember how many drives in it) is a GPT disk, formatted with NTFS and defaults. My VM store is actually using ReFS though (I wanted storage pooling), so we will see how that goes. It is also using defaults otherwise.
erickotz is offline
post #18 of 19 Old 01-01-2013, 12:30 AM
robnix's Avatar
Quoted: 661 Post(s)
Liked: 494
I'd really like to hear some specific examples on how using larger than 4k cluster sizes have caused issues with 3rd party software. Nothing I've used over the last 15 years I've been in IT has had an issue with it.
Currently I manage the storage, ESX, and backup environment for my company. We have EMC, Nimble, and custom built storage spread across our datacenters.
Let's use backups as an example. We do disk to disk backups for all of our data, as stated, our backup volumes are for the most part too large to use 4k sizes. No issues on any of them due to the cluster size being set at 64k, even on our replication servers that hold several million files with sizes ranging from a few k to close to a TB in size. Thankfully I can use larger than 4k sizes without worry.
We use three separate backup software for our backup and replication tasks. ALL of them recommend using the largest cluster size available for the volume in order to increase performance and reduce fragmentation. Testing has borne out their recommendations. Backup Exec for example really likes a 64k cluster size.
Use the cluster size that fits the application or data, not some mythical "anything over 4k is bad".
Looky here!
post #19 of 19 Old 01-01-2013, 11:28 AM
erickotz's Avatar
Liked: 30
I'll try and ping one of my friends that is still there and see if I can get a better answer. Certainly some, perhaps even most, software handles it fine. But some doesn't. Even aside from that, I think we can all agree it's a far less tested path than the default size, and just by being non-default, is more likely to hit issues.
Like I said, until I left for Ceton last year, I worked as a Senior Support Escalation Engineer at Microsoft on the Core team, which (among other things) handled disk support. We were the escalation point. If you ever had a Premier contract and reached the escalation group for a disk issue, there was about a 1/12 change you spoke with me. I'll see if I can get one of my friends that is still there to give more details on the "why"
erickotz is offline
Reply Home Theater Computers
