CALM act compliance - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-29-2012, 02:54 PM - Thread Starter
ajkrishock's Avatar
Quoted: 76 Post(s)
Liked: 33
All,
If you are using a ceton infinitv (or other similar device) for live TV reception, What specific steps did you have to take (if any) in order to bring your service in compliance with the CALM act? Specifically, did you have to do something to your equipment like remove and re-insert your cable card, etc..
I'm using FIOS here and the commercials are about 5x the volume of the shows I'm watching. Verizon (predictably) is denying all responsibility and is instead blaming the advertisers.
Is there something I need to do to my infinitv / cablecard combo?
ajkrishock is offline
post #2 of 2 Old 12-29-2012, 03:46 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
CALM act is the responsibility of service/content provider, not end user. You don't need to do a thing (and really nothing you can do about it other than turn the volume down). If Verizon doesn't comply, you can report them to FCC. On the other hand, IIRC, this act was just recently passed. As always, you can expect that there will be months or years before it can be enforced.
You can also spend $$$ to buy some expensive high end receivers that includes functionalities to auto-level the loud commericals. But why spent your own money to do that when it is your service provider who is responsible.
Foxbat121 is offline
Reply Home Theater Computers
