3D Blu-Ray .ISO Playback on Macbook Pro to Samsung ES7500 3DTV (Bootcamp)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-30-2012, 04:42 AM - Thread Starter
Sensorei's Avatar
I am at my wits end after trying everything I can think of to get my 3D .ISOs to play in 3D on my TV from my retina macbook pro. I am running Windows 7 through bootcamp and using PowerDVD 12. My Macbook Pro is connected to my AVR which is an Onkyo HT-R548 which connects to my Samsung ES7500 TV. I can play 3D .ISOs just fine using the same setup with my PC instead of the MBP so there is definitely nothing wrong with my HDMI cables.
I have run 'Cyberlink Blu-Ray Disc and 3D Advisor' which has scanned all my hardware and everything has passed for 3D ISO Playback. When I play a 3D .ISO PowerDVD gives a message "Your 3D hardware only supports viewing of 3D movies in full screen mode. Would you like to enter full screen mode now?". This suggests that PowerDVD recognises that my setup should be switching to 3D mode, but it just plays in 2D even though the 3D icon is enabled.
I have tried EDID overrides for an Onkyo/Samsung but it doesn't help. No 3D!!!
I don't know what else to try! Please help guys.
Sensorei is offline
post #2 of 8 Old 12-30-2012, 05:29 AM
acejh1987's Avatar
Does 3D work if you connect the Macbook directly to the TV?
acejh1987 is offline
post #3 of 8 Old 12-30-2012, 06:06 AM
sharangad's Avatar
Did you enable 3d from the nvidia control panel?
sharangad is offline
post #4 of 8 Old 12-30-2012, 10:18 AM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
Is hdmi 1.4 required on the MBP? I'm just guessing.
audit13 is offline
post #5 of 8 Old 12-30-2012, 10:40 AM
acejh1987's Avatar
I think it has HDMI 1.4.
post #6 of 8 Old 12-30-2012, 12:16 PM - Thread Starter
Sensorei's Avatar
I didn't see an option for that. Will have another look.
Sensorei is offline
post #7 of 8 Old 12-30-2012, 12:18 PM - Thread Starter
Sensorei's Avatar
It also doesn't work if I connect directly to the TV. The mac has a Nvidia GT650m so it is HDMI 1.4.
Sensorei is offline
post #8 of 8 Old 01-09-2013, 02:10 PM - Thread Starter
Sensorei's Avatar
Still no luck getting 3D playback working. :banghead: There is also no option to enable 3D on the Nvidia control panel- not sure if there works be?
Has anybody gotten a 3D iso to play in 3D from their MacBook Pro to a Samsung 3D TV? confused.gif
Sensorei is offline
Reply Home Theater Computers
