DVD Scaling - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-30-2012, 03:07 PM - Thread Starter
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I was wondering what other members liked to use for DVD scaling on their PCs? I've set up MPC-HC with Madvr and LAVfilters following MindBomb's guide. I also use TMT5 with SimHD and WinDVD Pro11. I did a test with Nausicaa of the Valley of the Wind and I thought MPC and WinDVD and looked pretty good but I thought TMT5 with SimHD was a little lacking. I found some settings here at AVS that mentioned setting scaling to GPU and setting sharpness to 1. Are there better settings for SimHD? What's your favorite way to scale DVD on your PC/HTPC?
anikun07 is offline
post #2 of 6 Old 12-30-2012, 05:17 PM
Tong Chia's Avatar
I have the Nausicaa DVD as well, it can benefit from final stage sharpening. I use MPC-HCs sharpen complex as a post scaling shader with LAV and MadVR
In order for this to work with MadVR, you need the latest released MPC-HC and the newer MadVR versions, the latest 85.7 has scaling performance improvements.
Tong Chia is offline
post #3 of 6 Old 12-30-2012, 05:19 PM - Thread Starter
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I don't know the versions I have but I just downloaded them this week so they should be the most recent. I'll check these settings. Thanks for the suggestion.
anikun07 is offline
post #4 of 6 Old 01-01-2013, 07:04 PM - Thread Starter
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Could you give me a little more direction on where to make those changes?
anikun07 is offline
post #5 of 6 Old 01-03-2013, 11:13 PM
Tong Chia's Avatar
Take a look here, just add the shaders per the instructions. MadVR and the latest MPC-HC will allow shaders, but nor when this article was written.
http://www.homecinema-hd.com/mpc-hc-shaders_en.html
post #6 of 6 Old 01-04-2013, 06:49 AM - Thread Starter
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Thank you, I will try this out tonight.
anikun07 is offline
Reply Home Theater Computers
