Tuning multiple channels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-30-2012, 06:10 PM - Thread Starter
awwende's Avatar
I'm looking for a media program similar to what time warner offers.
The nice thing about timer warner's DVR was being able to use both tuners so that when I switch back to my last channel I could still rewind live TV. From what I've seen WMC cannot use mutiple tuners to save without recording the show. Is there a way to do this in WMC? Since I have a feeling the answer is going to be no, is there an alternative to do this on another program? The tuner I'm using is an homerun prime.
I'm not sure what the technical jargon is for what I'm describing, so hopefully you guys can understand what I'm trying to say. Thanks for the help in advance.
awwende is offline
post #2 of 7 Old 12-30-2012, 06:17 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Using an extender and two HDMI inputs on your HDTV will accomplish this.
Sammy2 is offline
post #3 of 7 Old 12-30-2012, 06:39 PM - Thread Starter
awwende's Avatar
There has to be a DVR program that can do this other than spending more money on an extender.
awwende is offline
post #4 of 7 Old 12-30-2012, 06:48 PM
sitlet's Avatar
Depends on what kind of tuner. If you are talking about a CableCard tuner, then no, the only way is to use Media Center, and that can only "watch" one tuner at a time. You would have to actually set the other tuner to record the other show, it's not constantly recording both tuners like a typical cable box does.
If you are talking about an ATSC or QAM tuner, you may be able to use two different TV programs at once. For example, my Hauppauge card came with it's own WinTV program, I could use that with one tuner, and WMC with the other.
sitlet is offline
post #5 of 7 Old 12-30-2012, 06:52 PM
dj4monie's Avatar
Quoted: 37 Post(s)
Liked: 25
In a word no. Go back to TWC boxes if that feature is a deal breaker. I can live without esoteric uses such as you mentioned.
A. Thomas
PSN - DJFourMoney
dj4monie is offline
post #6 of 7 Old 01-01-2013, 03:06 AM
Puwaha's Avatar
Liked: 35
You aren't using a DVR correctly.
Puwaha is offline
post #7 of 7 Old 01-01-2013, 12:46 PM
captain_video's Avatar
Quoted: 511 Post(s)
Liked: 337
Just how do you think you're able to rewind "live" TV if it's not being recorded? Your DVR probably has a buffer that's constantly being updated with recorded content. If you have two programs that you want to switch back and forth between, simply record each one and switch back and forth between them. I do this all the time in WMC when there are multiple football games I want to watch. I'll watch one game for a while and then stop it. I'll then start playback of the other game and do the same. I generally try to watch it in short spurts, usually during one team's complete possession of the ball, so I don't accidentally see a score update for the other game being shown at the bottom of the screen. This way I can keep relatively current with each game and still be able to skip past all of the commercials.
captain_video is offline
Reply Home Theater Computers
