Can you tell the difference between a blu ray and a x264 copy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 12-31-2012, 03:34 AM - Thread Starter
cedivad's Avatar
The Dark Knight Rises.
The Blu Ray is about 50GB for about 30MB/s. The x264 copy is 17GB for about 12MB/s. Here are 2 pics of details of the movie. I don't think to be any visible difference.
BD:
RIP:
BD:
RIP:
So my question is, if you (we) can't tell the difference, why should i want a file that is 3x bigger? I guess i will not lose time doing 1:1 copies of Blu Rays :=)
cedivad is offline
post #2 of 28 Old 12-31-2012, 07:06 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
It depends on more than just static images on a web forum.
When I got my first hdtv, a 37" 720p model - I thought my PC was great at upscaling. I couldn't tell much of a difference between my DVD discs and the 1.5gb xvid avi files I made from them with AutoGK.
Then I got a 50" 1080p display and that line of thinking went out the window. Even DVDs look relatively lousy on it.
I probably would compress some things now that I use bluray, especially comedies. But it takes over 18 hours to do a single movie in Handbrake so I don't bother.
bulls likes this.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #3 of 28 Old 12-31-2012, 07:17 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I ripped the Dark Knight Rises and it is h.264 at 30Mbps. Why did you compress it?
Sammy2 is offline
post #4 of 28 Old 12-31-2012, 07:42 AM - Thread Starter
cedivad's Avatar
I'm sorry, but i don't think so. Movies are static images. The plane photogram is exactly the same, compressed and not. So the movie is exactly the same. I'm now running the two movies on fullscreen on the same time pressing cmd/tab to switch among the 2 versions, pause the movie and examine the single photogram. I found some differences on some IMAX night scenes of the city. However, it takes at least 20 seconds to see these differences. Really imperceptible.
This one is the most visible so far:
Let's say that if you want to store everything in the cloud you also save bandwidth.
cedivad is offline
post #5 of 28 Old 12-31-2012, 08:03 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
And they are .jpg images to boot!
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #6 of 28 Old 12-31-2012, 08:15 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Okay. You still need probably a 50Mbps internet connection for that and a the same up speed to get it there in a decent amount of time.
How much can you store in the cloud that you have and how do you access the cloud library quickly for playback?
Sammy2 is offline
post #7 of 28 Old 12-31-2012, 08:31 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
I can tell the differences posted in OP in the factor of obvious compression artifacts. Even if you re-compress it into 30mb/s H.264, you will still see those artifacts in most cases because compressing a video is more than just press a button.
Yes, compress it down to 12mbps is good choice between storage/bandwidth requirements and visual artifacts. But don't think for a minute that you can't tell a difference. It's a sacrifice you choose and live with it.
It you know where to look for the defects, it is easy to spot. On a bigger screen, these artifacts will be more obvious than your PC screen.
Foxbat121 is online now
post #8 of 28 Old 12-31-2012, 08:33 AM
sitlet's Avatar
Umm, not exactly. Movies are a SERIES of static images. You cannot tell based on one frame how compressed a movie is going to look. Motion plays a BIG factor in that. Try capping a frame with an explosion or fast moving objects, you will notice.
No it's not. No matter how little you compressed it, it's still compressed, meaning you did lose some bits of the original.
sitlet is offline
post #9 of 28 Old 12-31-2012, 08:37 AM
Louquid's Avatar
Liked: 38
I've always found the imperfections of compressed Blu Ray rips have always shown with movement in the scene. The fluidness is where you see the loss of quality. Pixelation, screen tearing, and washing out of dark images.
Though compressing down to 17gb you probably won't be able to notice these things as easily as if you compressed it down further.
Louquid is offline
post #10 of 28 Old 12-31-2012, 09:18 AM
jvarisco's Avatar
There's a lot of reasons, many of which overlap.
First, more bitrate does not always equal better. There's a huge point of diminishing returns on encoding 1080p video. That breakpoint varies greatly depending on the original video and how much care you give the encode, but it is there. The first "Avatar" disc is a great example. The first version had nothing other than the movie, because it was claimed it would compromise the video quality to encode to a smaller file size. Then the special feature versions arrived and people couldn't see any difference with the lower bit rate discs.
Second, most people far overestimate their ability to perceive differences in media encoding. Some go so far as to invent things that aren't there. You see this most often with audiophiles' "golden ears", but I'm sure there's plenty of "golden eyes" on this forum. The only proper way to test would be a double-blind setup. However, for your purposes, if you can't see a practical difference, then rock on with your encoding. I might recommend testing it on a couple different movies just to confirm that you see consistent results in multiple cases.
I will concede that the encoding tools you and I have are probably not nearly as good as the professional mastering houses, and we also don't have access to the original source - which means joe average ripping a retail BR is going to have the potential for problems/reduced quality. But as you've shown that's not always the case.
With this in mind, why do huge encodes on Bluray? Well, because there' space for it on the disc! There's no harm or additional cost in doing a 50G encode vs. a 17G encode, so why not? If anything it's in the studio's interest. It's less work for them to get a good encode since they have more space than they really need. It's also is a great selling point for videophile review sites - they always mention bitrates in their reviews.
cedivad likes this.
jvarisco is offline
post #11 of 28 Old 12-31-2012, 11:28 AM
pokekevin's Avatar
Liked: 102
On my calibrated plasma I was able to tell differences when it came to colors. I experimented with compressed my bd iso rips back when 2tb hard drives were the only thing around and were expensive.
pokekevin is offline
post #12 of 28 Old 12-31-2012, 02:08 PM
Yunus's Avatar
I recently did a blind test by having a friend play a scene from a blu-ray playing on a PS3 and the same scene from a ripped and compressed version on my HTPC, I can't play Blu-Ray's on my HTPC. Original was 18 gigs, compressed it was 4 gigs. I did actually pick correctly but I was guessing, I couldn't tell the difference. While I am sure there is a difference, I can't see it or hear it.
Yunus is offline
post #13 of 28 Old 12-31-2012, 02:28 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
If the encode was done well from a person who understand all the various settings then it would be difficult for me, even on a calibrated monitor. I could pick up the differences if I were to capture the images and compare them side by side but in motion, definitely not.
BD:
RIP:
This set of pictures are exactly the same, which is not possible.
Mrkazador is offline
post #14 of 28 Old 12-31-2012, 04:17 PM
Defcon's Avatar
Quoted: 1104 Post(s)
Liked: 572
I'd like to add that in many cases, HD audio is also hard to tell apart from a DD/DTS track. Although this of course depends almost completely on your audio gear, I believe there were articles in the usual audio rags about how it was hard to distinguish. Same thing applies for music ripped to FLAC vs high bitrate mp3/wma/aac.
This is an age old debate. Ripping started because disk space was limited. Then the typical argument became - disk space is cheap, why not keep in the best format possible, you can always down-encode later. But now we've reached a point where the encoders are really good and space is again becoming costly.
I've spent a LOT of time ensuring perfect rips, 720p vs 1080p etc, and in the end realized I watched the movie only once and spent far more time on ripping it :)
cedivad likes this.
Defcon is offline
post #15 of 28 Old 12-31-2012, 04:57 PM - Thread Starter
cedivad's Avatar
Look at the shadows of the broken wings, they are different. These are really different encodings, it's just that the rip one is really well done! smile.gif
cedivad is offline
post #16 of 28 Old 12-31-2012, 07:27 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Either you changed the images or I was looking at the same picture lol.
post #17 of 28 Old 12-31-2012, 08:28 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Since most of the compression is accomplished by eliminating the common part(s) between frames or in other words recording just the differences I too am of the opinion that static images are useless as a means of comparison. Especially because those still shots are compromised by being further compressed by .jpg algorithms. To those who say they are identical, check the filesizes:
olyteddy is offline
post #18 of 28 Old 12-31-2012, 11:00 PM
vladd's Avatar
Liked: 39
Which means absolutely nothing unless the pics are cropped exactly the same (which they aren't). It would have been better if the OP had posted uncropped (and non JPEG compressed) images (which still would not show frame transitions).
If you are saying they are not the same pic, then I agree but we would have to take the OP at his word that they are pics of different source encodes. As you said, these images are useless for comparisons.
vladd is offline
post #19 of 28 Old 01-01-2013, 01:11 AM
jdastas's Avatar
18hrs sounds like a lot, what kind of hardware are you running?
I just ripped the first Pirates of the Caribbean. 30GB file down to 10, took about 1hr45min.
jdastas is offline
post #20 of 28 Old 01-01-2013, 02:48 AM - Thread Starter
cedivad's Avatar
Mod's edit: Piracy talk removed.
About the storage space, i have 4U storage server i use for my work (and for several terabytes of backups or real data). It's not a space issue for me. I don't think to really have a canche to fill that storage server with BD rips. However, this is not the point of the thread. The point is, is there any visible difference among the 2 versions? The answer is that no, there is not. Its like finding the difference among pepsi and coca cola.
cedivad is offline
post #21 of 28 Old 01-01-2013, 03:06 AM - Thread Starter
cedivad's Avatar
Shouldn't static images in the middle of an "battle" or "run" scene be different from the original following your thinking? I think that since that i can't find any visible difference among the frames of the 2 versions, there shouldn't be any. Maybe i misunderstand what you are saying, my english is not that good.
Low compression JPG, it's hard to tell from the original.
This to me has the same meaning of doing a md5sum of the file. Also, yes, i cropped the screen by hand, they have a different size and filesize.
cedivad is offline
post #22 of 28 Old 01-01-2013, 03:23 AM
acejh1987's Avatar
No, i've tried that one as a reference to know how people with more experience than me encode those movies. To learn. rolleyes.gif
No - There is a difference, you just are not able to see it like some others can, just like some people can tell between pepsi and coca cola.
Stop trying to convince people otherwise.
acejh1987 is offline
post #23 of 28 Old 01-01-2013, 03:42 AM - Thread Starter
cedivad's Avatar
original 2303k .png file
rip 2086k .png file
As you can see the original one is 0.3MB bigger.
Please point me out the visible differences you would see during the screening of the movie. I know that they are different. But you wan't be able to distinguish the original from the other one. If you are able to, please tell me how you could with that pics.
cedivad is offline
post #24 of 28 Old 01-01-2013, 03:54 AM
acejh1987's Avatar
If the screenshots are from different sources then the argument is void anyway, your original is from the Italian BD, and the torrent rip as you have pointed out isn't.
I'm not saying I would even see a difference, but some people do and you can not convince them otherwise.
I know I have the best quality possible already, space is not an issue so I do not need to waste time encoding/downloading torrents, even if I couldn't tell the difference.
post #25 of 28 Old 01-01-2013, 04:01 AM - Thread Starter
cedivad's Avatar
Take your tdkr BD and you will see that it has an Italian audio track. We own the same BD and it has sense to think that whoever did the torrent rip own the same.
So, the source is the same, and the derivate is impossible to to tell from the original.
cedivad is offline
post #26 of 28 Old 01-01-2013, 04:15 AM
acejh1987's Avatar
Its not impossible to tell the difference between an original rip and a 12Mbps x264 encode.
It is impossible to convince someone what they can and can not see.
post #27 of 28 Old 01-01-2013, 04:18 AM - Thread Starter
cedivad's Avatar
To prove your thesis, show me a sensible difference among the 2 versions. Ask me to post x photogram. You are correct, it's not impossible, it's only humanly impossible.
Thank you @ forum for the conversation, anyway.
cedivad is offline
post #28 of 28 Old 01-01-2013, 04:32 AM
Super Moderator
Bob Sorel's Avatar
Quoted: 73 Post(s)
Liked: 126
This thread is pointless....time to close it.
Bob Sorel is offline
Closed Thread Home Theater Computers
