Best large drive for HTPC storage + quiet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 12-31-2012, 02:51 PM - Thread Starter
micko_escalade's Avatar
Quoted: 21 Post(s)
I was looking over at tomshardware HD charts and Seagate Barracuda 7200 3TB http://www.amazon.com/Seagate-Barracuda-3-5-Inch-Internal-ST3000DM001/dp/B005T3GRLY
caught my eye for both price and size.
In my current system I already have 128GB SSD so just need something for HTPC storage.
After, I've started reading thru the forums and kinda got a feel that 3TB can be hassle for widows 7 to recognize it as a 1 drive and other one was loudness.
Can you guys recommend something better or my assumptions are wrong?
TIA
TV - Samsung LED 55" TV Service - Comcast (X1)
Receiver - Marantz SR7011
Speakers - Front L/R - Definitive Technology BP9040 Center - Definitive Technology CS9040
Surround - L/R - Pioneer S-H253B-K (Will be replaced, slow build out)
Cabinet cooling - AC Infinity AIRCOM T8 (Rear exhaust)
micko_escalade is offline
post #2 of 31 Old 12-31-2012, 06:59 PM
sycochkn's Avatar
I use the WD/HGST green drives. I am going to migrate to 4 TB drives so 7200 rpm is my only choice at the moment. I use windows 7pro 64 so no problem recognizing larger drives.
sycochkn is offline
post #3 of 31 Old 12-31-2012, 07:02 PM - Thread Starter
Quoted: 21 Post(s)
Thanks for the reply!
What particular models of those do you have and how loud are they?
post #4 of 31 Old 01-01-2013, 02:47 AM
steelman1991's Avatar
Quoted: 296 Post(s)
Liked: 149
TIA
Got several of these (5) in my set-up - no issues at all with windows 7 recognition, cannot comment on noise, system based in another area of the house (loft), but while in that vicinity there seems little discernible noise from them
See here for discussion on how and what to format to http://www.avsforum.com/t/1447467/best-way-to-format-and-set-up-new-hdd-for-media-storage-3tb-what-format-type-and-sector-size-advice. Me I format to default settings using Windows Disk Management - no problems of any kind.
steelman1991 is online now
post #5 of 31 Old 01-01-2013, 09:47 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Yup. Seagate 3TB is fine. Just install it defaults. Windows will see it as one drive. No worries.
Mfusick is offline
post #6 of 31 Old 01-01-2013, 11:16 PM - Thread Starter
Quoted: 21 Post(s)
Good to know that windows will see it as 1 drive.
Since WD Red's http://www.newegg.com/Product/Product.aspx?Item=N82E16822236344
are 5400RPM I would imagine they're more quiet? Does anyone has these?
It appears that Seagate is better then WD.
Since its for HTPC I would prefer it to be more quiet.-
post #7 of 31 Old 01-02-2013, 06:34 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
RED is very quiet and low noise. It's basically a newer and better GREEN drive with intellipark head parking turned off for increase reliability and performance in 24/7 NAS like applications.
Seagate isn't excessive loud though. It's a faster 7200 drive so ...
Decide what's the most important. Both are good.
Mfusick is offline
post #8 of 31 Old 01-02-2013, 12:43 PM
chappy16775's Avatar
I'm shopping for a few 3TB drives for my new XBMC media server with Flexraid. I was led to believe the WD Red's are the ones to go for these days. The marketing on those is very slick but can anyone opine on whether it's worth paying $20 extra for the WD Red over this Seagate 3TB as shown in the original post? My server will be housed outside of the living room so noise not an issue.
chappy16775 is offline
post #9 of 31 Old 01-04-2013, 06:54 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I think it depends on price. For a basic media server they are typically located in a non critical area for noise. What I mean is a relatively quiet HDD is totally tolerable because the server isn't in a bedroom or close to your viewing area. In my case my server is in a room where a small amount of noise isn't noticed and no one cares.
Same on heat issue. Typically servers are built in larger chassis with better cooling and most server builds use HDD cages with fans on them. So if a Red is 85 degrees uncooled and a Seagate is 90 uncooled then either is fine in a well cooled server set up.
I think if I was trying to cram a pair if these HDD into a really small HTPC case I'd pay more attention to the heat and noise issue.
If I was installing them into a home server ( and I have). I'd focus more in reliability, performance and price.
To me the Seagate wins performance and price. They tie on reliability. my personal value system weights the price issue more heavily so I went Seagate on my last 5 drives.
$20 or less difference its tougher choice but for $20 or more its easy to me.
I'd vote Seagate. It's not like they are excessively loud. They are on par with RED and it would take a special circumstance setup or a very critical person to find issue with them. Those people should buy RED.
Mfusick is offline
post #10 of 31 Old 01-04-2013, 08:10 AM
ForeverSilent004's Avatar
I just bought a Synology DS413 4-Bad NAS and filled it with 4x3TB WD Red drives in RAID5. Very quiet, very happy.
TV: Panasonic 50" ST50 1080p Plasma
Audio: Yamaha Aventage A710 / Polk Audio RM510 5.1
Remote: Logitech Harmony 510 / Logitech MX Air mouse / Lenovo N5902
HTPC: Silverstone SG06 / Intel i7-3770S / XFX 7870 DD / 840 Pro 256GB / Windows 8 Pro / Synology DS413 + 4x3TB WD Red RAID5
Build: http://pcpartpi...
ForeverSilent004 is offline
post #11 of 31 Old 01-05-2013, 12:16 AM - Thread Starter
Quoted: 21 Post(s)
If you say 4 of them are quiet then I'm pulling the trigger and getting one biggrin.gif
post #12 of 31 Old 01-05-2013, 12:19 AM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
How are the Red drives? I always use the greens use Im just using JBOD. Was considering getting the reds
pokekevin is offline
post #13 of 31 Old 01-05-2013, 07:49 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
RED is better than green. Lower power, better performance, increased reliability and longer warranty.
Mfusick is offline
post #14 of 31 Old 01-05-2013, 11:10 AM - Thread Starter
Quoted: 21 Post(s)
Thanks guys!
I made up my mind and will be getting RED!
post #15 of 31 Old 01-05-2013, 11:24 AM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
Quite a bit of misinformation here.
Not necessarily true (see below)
Lower power,
Not in my testing. Reds use about 2-3 watts more which is potentially a substantial difference if you are using multiple.
better performance,
Likey true in benchmarks but completely irrelevant for HTPC storage and playback. The typical HTPC user won't notice a bit of difference.
Absolutely no proof to this statement at all. Please post a reference for this claim.
True.
One should also realize that Mfusick has had a few Green drives fail and now isn't as high on them. We have used hundreds professionally with absolutely no issues. I have 8 personally currently. My friends in my local area haven't had issues who I have built HTPCs for (some of which use Green drives for their OS as well as they have had these drives long enough where at the time a 64 GB SSD was $130). Oh, and then there are the hundreds of users on AVS that have used Green drives without issue as well. The things that WD Red touts as benefits are largely not needed for Win 7/8 or Software RAID. The Reds aren't "bad", I just don't think they are clearly "better".
My $.02.
assassin is offline
post #16 of 31 Old 01-05-2013, 11:54 AM
andersa's Avatar
Quoted: 36 Post(s)
Liked: 33
In 2012 I RMA'd one 2TB Green drive in February and a 2nd one in December. I also have two 1TB Green drives that CrystalDiskInfo report bad sectors on.
Also in 2012, I had 1 1TB Toshiba 2.5" drive fail and 1 320GB 2.5" Seagate drive fail. I also have a 2TB Seagate drive in a whs1 server that has been failing a couple of times, only to show up healthy again after a reboot or re-install. I'm thinking it can be due to the advanced formatting that whsV1 doesn't really support, but I don't know for sure. I'm in the process of migrating to whs2011 right now though.
I also have a 720 GB Seagate that CrystalDiskInfo reprort bad sectors on.
So in my home the Green drives have had the most problem in 2012, but it's also the type of drive that I have most of, usually because they are the cheapest.
I'll probably start buying Red drives too for the heck of it. The extra $$ would be well worth it if the added reliability really is there, only time will tell.
/Anders
andersa is online now
post #17 of 31 Old 01-05-2013, 12:13 PM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
/Anders
I have RMA'd some 7200RPM drives in the past as well. Doesn't mean anything at all other than all hard drives can fail. Doesn't mean that I think they are bad drives either. I just don't think they are as good for storage.
Little known fact: Black drives have "head parking" as well. Yet no one seems to regard them as "less reliable" because this fact is not widely known to most end-users. Reference
assassin is offline
post #18 of 31 Old 01-05-2013, 01:48 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
True.
My $.02.
You just saved me some money:D
post #19 of 31 Old 01-05-2013, 03:34 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I have a 3tb green and two 2tb greens I will sell ya.
I'd love replace them with a better variant.
They are new and under warranty. RMA replacements for previous failed units.
Still in factory package unopened.
Let me know. I'll sell cheap.
Mfusick is offline
post #20 of 31 Old 01-05-2013, 03:42 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
You always say this but no one cares cause no one uses black drives.
They are worst possible choice. They are so old that they are not faster anymore and they totally suck at energy/heat/noise. They also suck on price. Reliability isn't superior.
Black is the worst possible choice for basically any application that comes to my mind.
Red is best. Green is second. For WD.
Seagate is best performance and value however. It's usually cheapest per GB. It uses less energy at idle than either a Green EARX or EARS too.
I'd like to see your data on RED vs Green because I've seen tests and reviews showing RED better in both energy and performance. It's certainly close enough that any difference is insignificant anyways. It's comes down to price. If RED is close in price it's a better choice IMO.
Mfusick is offline
post #21 of 31 Old 01-05-2013, 03:44 PM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
Yes, you have already stated as much multiple times in this thread and others.
assassin is offline
post #22 of 31 Old 01-05-2013, 03:45 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
If GREEN is stupid cheap it's a fine choice too btw... But I'm not paying retail for those or more per GB that a better Seagate 3TB/Red
Mfusick is offline
post #23 of 31 Old 01-05-2013, 03:55 PM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
I never said anything about Seagate.
Maybe you should question the shipping and handling from where you purchased your Green drives and even the lot of the failed drives that you have assuming they are the same (instead of bashing all of them of course). Maybe even reconsider how you have handled and used your drives (I have seen your posts on another forum where you seem to boast about how "rough" you are on your Green drives).
assassin is offline
post #24 of 31 Old 01-05-2013, 03:57 PM
I opted to pay $20 more for the 3TB Red vs the Green. I think the 3year warranty is worth that alone.
post #25 of 31 Old 01-05-2013, 04:04 PM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
Certainly a valid reason to buy a Red drive over a Green.
As I state in my guides anything over $20 more to me for a Red drive is questionable, imo. At $10 more its almost a no-brainer to go with the Red (even more so with a 3TB as its a lower overall percentage of the total cost) for the added year warranty alone.
I have had other hard drives fail a few months before and a few months after the warranty.
assassin is offline
post #26 of 31 Old 01-05-2013, 04:12 PM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
just added two 3tb seagates. wow do these run cool compared to some older 500gb samsungs and even my beloved 2 tb samsung f4s.
no clicking or noise that i can hear. from them. and stupid fast.
aliaskary77 is offline
post #27 of 31 Old 01-05-2013, 04:15 PM
ljo000's Avatar
Just FYI I was in Costco today and saw they had 4TB drives for $180. I only saw the poster and not the actual drives but I think they're external and probably Seagate.
ljo000 is offline
post #28 of 31 Old 01-07-2013, 12:21 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
No.
I bought a WD external from Costco with a 3TB green inside. Cracked it open like countless others.
I bought a 3TB green from Newegg. It came packaged the same as the 25 other HDD's I've gotten from them.
I also bought a few 2TB greens. Both EARS and EARX models.
I have RMA at least one of the EARS and EARX 2TB WD greens, and also at least one of the 3TB EARX WD Greens. I recieved all three back RMA from WD directly. Packaged from them. Now, I am having issue with two of the RMA replaced models.
I'm batting close to 100% on WD issues with greens.
Keep in mind I have 6 total WD green drives purchased over 2 year span from various locations. All locations are popular legitimate locations most users here purchase from.
I think the high amount of copy paste and how I use my drives might be a factor. I noticed that when the green drives fill up on my server they always slow down to under 30MB second speeds reading. That also sucks.
I have 4 in my server now. All full. All slow. All read under 50MB/sec
In contrast I have 4 Seagates all full too. They read at 100MB/sec+
I'm not a fan of WD greens.
I used to be. I've change my mind from poor user experience. I was once recently a die hard WD guy.
I know 50MB/sec is perfectly fast to stream even two HD movies at once- but it's still unacceptable to me.
You will never convince me there is not a performance penalty with a WD green that is increased significantly when the drive is near full. In FlexRaid- it usually fills up one drive before it starts storing on the next. I know I can set a reserve space but setting a reserve greater than 50GB seems like a major waste of space to me. If you take a Green Drive past 100GB or less free space they get slow...
That's just another negative I have experienced.
I really hate to bash on them so much. I think they are fine for ordinary use. But they obviously have a few drawbacks.
If they are not cheaper they are a poor choice because they don't save a considerable amount of energy and the reliability appears to me to be more suspect. (opinion). There is a very real performance penalty. And- the head parking feature that was designed to save additional energy appears to lower the life span of the drive as compared to a model without head parking. I'm not sure the decreased reliability is worth the very small energy savings that feature provides.
I'd rather a RED with a longer warranty and no Head parking (better performance too) or a Seagate without head parking (also great energy performance and speed).
Green only makes sense when it's WAY CHEAPER than anything else. It's not that it is a poor choice. It's just not a very good choice most of the time.
Mfusick is offline
post #29 of 31 Old 01-07-2013, 12:26 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
yup.
My buddy grabbed one saturday.
Same drive inside they sell for $299 most places.
Great deal.
$40 per GB and a huge drive.
Uses more energy than a 3TB Seagate though.
Costco also sells the same 3TB version for $120. Same cost per GB. I like the 3TB drive better. It's a 7200.14. It's a great drive.
I've bought and cracked open more than a few of those with excellent luck.
I have 7 total and none have ever given me any issues (yet)
I've removed all the green drives from my server in favor of these.
('I'll sell new unopened RMA replacements direct from WD cheap to anyone that wants them. I have a few 2TB and 3TB WD greens I RMA-ed and have not opened or used the replacement they sent me.)
Mfusick is offline
post #30 of 31 Old 01-22-2013, 12:20 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I am not sure the 4TB has the energy profile or performance of the 3TB though....
I'd be curios if anyone knows? ????
Mfusick is offline
Reply Home Theater Computers
