Issues with Audio Out Blu Ray Playback WMC 7 w/ TMT5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-02-2013, 11:44 AM - Thread Starter
lokie56's Avatar
I am currently using Total Media Theatre 5 for my Bluray play back. When using the app itself and when I plug headphones in I have no issues, the audio switches over to my headphones.,
When playing it directly in WMC7 however and I plug headphones in, the audio keep coming out of the speakers. I've updated driver, tried installing settings, but its ONLY when blu ray playback is involved, and other video files played in wmc works fine. Any tips? Thanks.
lokie56 is offline
post #2 of 5 Old 01-04-2013, 03:59 PM - Thread Starter
lokie56's Avatar
any body have any clues?
lokie56 is offline
post #3 of 5 Old 01-05-2013, 12:02 AM
sitlet's Avatar
You need to correct codecs/software to play back blu-rays on a pc. I'm guessing one of those is the issue.
sitlet is offline
post #4 of 5 Old 01-06-2013, 10:09 AM
rshack's Avatar
I'm pretty new to TMT5 myself, but I believe when playing a blu-ray through it (or any file for that matter) you need to go the AV menu at the top and specify you want the sound to come out of the headphones. By default I believe the program directs the sound to the computer speakers.
This link might also prove useful to you: http://www.arcsoft.com/totalmedia-theatre/tutorial/how-to-set-audio-output.html
rshack is offline
post #5 of 5 Old 01-09-2013, 01:04 PM - Thread Starter
lokie56's Avatar
I did that in TMT5 and it works with that but when playing back blurays through WMC refuses to switch which is a little annoying, anyone with powerdvd have this issue? Does powerdvd integrate now like tmt5 does with WMC?
lokie56 is offline
Reply Home Theater Computers
