wmc and 3tb external harddrives - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-03-2013, 10:17 AM - Thread Starter
lars60's Avatar
dvd rips freeze or wont play at all in wmc. they play fine in external players or fine in wmc riped to internal harddrive.. anyone run into this before?
lars60 is offline
post #2 of 7 Old 01-03-2013, 10:35 AM
sitlet's Avatar
More information would help. Like how you ripped them, what format, what codec, what resolution, etc. Based on your thread title, it seems that you think the hard drive is to blame, which it isn't.
sitlet is offline
post #3 of 7 Old 01-03-2013, 10:52 AM
ljo000's Avatar
Are the external drives powered or unpowered? If they are the latter, try a different port and make sure not to use the front panel ports as I've found these can lack power.
ljo000 is offline
post #4 of 7 Old 01-03-2013, 04:03 PM - Thread Starter
lars60's Avatar
the drive is powered the files videots. they work fine on everything but wmc. no problem with files on smaller external harddrive or the 1tb internal drive. seems to be wmc has problem with external 3tb drives.
lars60 is offline
post #5 of 7 Old 01-04-2013, 10:03 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
How was 3 Tb drive formatted?
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #6 of 7 Old 01-04-2013, 10:20 AM - Thread Starter
lars60's Avatar
I have tried gpt and mbr with different sized partions ntfs with default allocation size
lars60 is offline
post #7 of 7 Old 01-04-2013, 04:04 PM
ljo000's Avatar
Sounds like a dud drive.
ljo000 is offline
Reply Home Theater Computers
