This looks good ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-03-2013, 03:33 PM - Thread Starter
scantek999's Avatar
Quoted: 23 Post(s)
Hello
Does this looks like a kickass setup, able to play all types of movies if, running XBMC on a Win7 sytem:
GIGABYTE GA-B75M-D3H (rev. 1.0)
Kingston 4GB DDR3 1600Mhz (2x2) HyperX
Intel Core i3-3225 Ivy Bridge - Box
Chieftec Flyer Series FI-01B
Kingston SSDNow V300 SSD - 60GB
Thank You!
scantek999 is offline
post #2 of 8 Old 01-03-2013, 04:10 PM
Tiddles88's Avatar
Liked: 24
You can save cash going for an Asrock B75 mATX board, and I'd change the SSD to a Samsung 830 60GB SSD. No PSU either, I'd get a Seasonic "G" series for quietness. And I'd choose Win 8.
Tiddles88 is offline
post #3 of 8 Old 01-03-2013, 04:26 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #4 of 8 Old 01-03-2013, 07:45 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Intel HD Graphics is still poorly supported by XBMC 12 Frodo for interlaced contents (the playback freezes if Deinterlace video: "DXVA Best" is selected, so you will be limited to "Bob" or some kind of crappy software deinterlacing eek.gif). AMD is the way to go for XBMC. If you play only films, either platform is good, of course. (Film is also bad with Intel + XBMC 11 Eden, 12 Frodo is better in this regard.)
renethx is offline
post #5 of 8 Old 01-03-2013, 11:44 PM - Thread Starter
scantek999's Avatar
Quoted: 23 Post(s)
Ok, does not sound good with the missing support from XBMC! What would a good alternative from AMD be ?
post #6 of 8 Old 01-04-2013, 12:06 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
A6-5400K, $70, is enough for almost every video playback task including BR 3D. Its graphics is overall better than Intel HD Graphics 4000. The processor (dual-core) is a bit weak for, e.g. 2D-3D conversion and real-time transcoding for another device such as iDevice. A8-5500 quad-core is a good choice for these purposes, in particular inside a mini-ITX case. The height of the stock cooler is 40mm, btw. Either ASRock or MSI mb should be good and either DDR3-1600 or 1866 is good, no big performance difference.
renethx is offline
post #7 of 8 Old 01-04-2013, 12:35 AM - Thread Starter
scantek999's Avatar
Quoted: 23 Post(s)
Ok, thank you !
Is this a better choice then ?
AMD A8-5500 CPU/APU - Box
GIGABYTE GA-F2A75M-D3H (Rev 1.0)
Kingston 8GB DDR3 1600MHz (2x4) HyperX
Kingston SSDNow V+200 v2 SSD - 60GB
post #8 of 8 Old 01-04-2013, 05:03 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
GA-F2A75M-D3H microATX motherboard won't fit a mini-ITX case. Choose either MSI FM2-A75IA-E53 or ASRock FM2A75M-ITX.
renethx is offline
Reply Home Theater Computers
