Recommendation for new low power Win8 setup with Uefi - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 01-07-2013, 04:15 PM - Thread Starter
allanmb's Avatar
I currently have an Athlon 605e setup with AND 785 chipset which gives me a 45w cpu and hardware h264 descaling. My biggest annoyance is that Win7 takes about 20secs to boot up into Media Center and I have experienced much quicker times with Win8 and the new fast boot when used in conjunction with UEFI. However, I am a bit out of touch with the current low power cpus so I was wondering if someone could recommend a setup. Ideally I would like all of the following:
1. Low power cpu as the htpc will be on for extended periods
2. UEFI compatible motherboard bios for fastest possible boot times
3. No need for gfx card to keep power down to a minimum.
I will be putting it inside a Silverstone CW03 case and connected via hdmi to a 1080p TV.
Allan
allanmb is offline
post #2 of 23 Old 01-07-2013, 04:58 PM
Puwaha's Avatar
Liked: 35
Use an SSD for the fastest possible boot times on your current or any future HTPC. On a fairly low-powered system I recently built, an SSD booted a clean install of windows and Media Center so fast the network connection hadn't even started yet!
Puwaha is offline
post #3 of 23 Old 01-07-2013, 06:59 PM
Tiddles88's Avatar
Liked: 24
Intel i3 3220 + Asrock B75 PRO 3 (full ATX). Sips power, slaughters that old AMD CPU in anything you'll throw at it.
Tiddles88 is offline
post #4 of 23 Old 01-07-2013, 07:11 PM
Dark_Slayer's Avatar
Quoted: 658 Post(s)
Liked: 434
WOW, Tiddles recommending an Asrock board. Guess that Geico commercial with pigs flying really happened smile.gif
Dark_Slayer is online now
post #5 of 23 Old 01-08-2013, 02:34 AM - Thread Starter
allanmb's Avatar
I should have said, but I am already using an SSD drive and it made a huge difference in booting times for Win7. Now the computer spends most of the time in POST, hence the want for UEFI.
Allan
allanmb is offline
post #6 of 23 Old 01-08-2013, 03:07 AM - Thread Starter
allanmb's Avatar
Thanks for the recommendation. I just had a quick read up on this and it would seem that for the extra few bucks, the i3-3225 would be worth going for. I don't play many games on this machine but just in case it would be nice to have a little extra grunt.
Having said that, the 'equivalent' AMD chip would seem to be the A10-5800K. Looking at the specs, it consumes less power but doesn't have quite the CPU grunt as the i3, however the on-board gfx performance of the AMD seems to be a lot better than the i3.
So, what do people generally think about the AMD chip? I am leaning towards it mainly due to the lower power, but with a benefit of better gfx over cpu performance in mind too.
Allan
allanmb is offline
post #7 of 23 Old 01-08-2013, 05:20 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
Low power and trinity (especially a8 and a10) don't exactly go together which is one of the op's key requests.
assassin is online now
post #8 of 23 Old 01-08-2013, 05:33 AM
mcturkey's Avatar
Liked: 43
Allan
Anandtech has been recording post times of motherboards now for awhile. Take a look at the chart at the bottom: http://www.anandtech.com/show/6516/z77-mitx-roundup-five-of-the-best-msi-zotac-asrock-evga-and-asus/17
Unfortunately, to get really fast post times, you pretty much have to buy a pre-built OEM system. My home system takes more time to post (roughly 12 seconds with just about everything disabled) than to boot Windows 8 (roughly 10 seconds). If I didn't have to wait on post, I'd be way more inclined to fully shut my system down when I'm done using it. I guess I'm just horribly impatient, and should be glad that it's faster from power-on to using the system than it was ten years ago. Of course, it's also much longer than what power-on to using the system was twenty years ago.
mcturkey is offline
post #9 of 23 Old 01-08-2013, 06:51 AM - Thread Starter
allanmb's Avatar
I'm not sure if they are setting the UEFI boards correctly for fast boot. It's possible to get into Win8 from flicking the on switch in under 5 seconds! That is POST time plus windows 8 boot time. See here: http://www.youtube.com/watch?v=JdOAvlncCOw
allanmb is offline
post #10 of 23 Old 01-08-2013, 08:25 AM
Quoted: 658 Post(s)
Liked: 434
What makes you think that it's lower power?
For the usage you initially described, I'd say an ivy i3 would use less power
The Asrock boards I've used (H61 and Z77) offer UEFI and an instant boot utility. Their FM1/FM2 boards offer this as well
Based on your first post, I can't see what you'd want a quad core for but if that's what really suits your fancy then I'd lean towards an ivy i5. I'm fortunate to live near several large computer retail stores that offer motherboards and boxed processors. If you are also near such an area, remember that you can purchase an i5-3570k and z77 motherboard for $235+tax (anywhere that will price match Microcenters printed ads)
post #11 of 23 Old 01-08-2013, 08:54 AM - Thread Starter
allanmb's Avatar
The power ratings were quoted here: http://www.bit-tech.net/hardware/2012/11/26/intel-core-i3-3220-review/7
It shows that the AMD is lower power on idle and higher power on load. For an HTPC the processor is much more towards the idle end so I think the AMD would be lower power on use as well as idle.
I agree though, I do not need quad core however if the power consumption is the same then I would go for the quad core over a dual core for the few times I could use it. Although it is not greatly important to me to have the quad core.
allanmb is offline
post #12 of 23 Old 01-08-2013, 09:45 AM
Quoted: 658 Post(s)
Liked: 434
What's shown in that bar chart is not the whole picture
Check out this guy's i3 http://ssj3gohan.tweakblogs.net/blog/6112/85w-core-i3-based-desktop-computer-%28english%29.html
The idle wattage is very efficient in both Ivy Bridge and the Panther Point PCH. It's the PSU and other junk on the motherboard that keep us from really seeing 20W idles regularly
Here is a link with some Idle vs load comparisons of the same processor but used in different A75 boards. Idles vary a lot http://www.neoseeker.com/Articles/Hardware/Roundups/amd_a75_motherboard_roundup/12.html
There are similar roundups out there for 6 series and 7 series Intel boards
post #13 of 23 Old 01-08-2013, 09:57 AM
mcturkey's Avatar
Liked: 43
I've never actually seen any proof of anyone doing that from a fully powered off system - forums are filled with questions on how to make that happen, and no success stories that I've found. I'd absolutely love to see it happen on consumer hardware, but I have yet to see it.
mcturkey is offline
post #14 of 23 Old 01-08-2013, 11:04 AM
Aluminum's Avatar
Quoted: 22 Post(s)
Liked: 25
His newer project is here:
http://ssj3gohan.tweakblogs.net/blog/8217/fluffy2-59-watt-high-end-desktop-computer.html
http://www.extremetech.com/extreme/135719-5-9-watts-the-worlds-most-efficient-high-end-computer
The DQ77KB that guy starts with is already has a pretty good built in DC psu though. I see nice low idles with my setups on the same board, I'll have to hook up the meter again and take some pictures.
It also has UEFI and can be set up to boot pretty fast. Also a lot of people forget to tweak the windows part of the boot to skip the logo and such, easy way to lose a few seconds.
When I stopped caring about super quiet: E5 1680v2 @ 4.5Ghz, 980ti, i750 SSD - JS9500 & Dell P2715Q for dual 4k@60 because reasons
SAN shares over 56Gb infiniband, microcenter + fleabay = severe risks to my wallet
Aluminum is offline
post #15 of 23 Old 01-08-2013, 11:49 AM
Quoted: 658 Post(s)
Liked: 434
Intel should hire this guy if they wanted to start making their own ultrabooks
post #16 of 23 Old 01-08-2013, 11:50 AM - Thread Starter
allanmb's Avatar
Its definitely possible. My desktop PC boots into Win8 in around 7 seconds!
allanmb is offline
post #17 of 23 Old 01-08-2013, 05:36 PM
mcturkey's Avatar
Liked: 43
Is this an OEM system, or custom built? And is that from full power off to desktop/login screen (not sleep/hibernate)?
mcturkey is offline
post #18 of 23 Old 01-08-2013, 06:20 PM
Tiddles88's Avatar
Liked: 24
Its 55w for Intel and 100w for AMD. No contest. Get the i3, faster, cooler and the onboard GPU is sufficient for your needs.
post #19 of 23 Old 01-09-2013, 03:01 AM - Thread Starter
allanmb's Avatar
It's a custom build using this mobo: Asus P8Z77-V DELUXE Z77 Socket 1155 8 Channel HD Audio ATX Motherboard
And that is from power off into Windows 8 desktop
allanmb is offline
post #20 of 23 Old 01-09-2013, 03:47 AM - Thread Starter
allanmb's Avatar
You are correct. I have, however, just read about the AMD A10 5700 which has a TDP of 65w. It would seem that this chip is much lower power than the Intel during Idle and lower under full load unless you are using the IGPs. This is my current preference so far as I think it would be :
- the lowest power of the bunch
- has best IGP perfomance if needed
Bearing in mind that I don't need the CPU performance that any of these chips deliver, if I did then the Intel would be the winner. Also, I will not have a separate gfx card in the setup to reduce power so the AMD provides the best balance for my needs, I think!
allanmb is offline
post #21 of 23 Old 01-10-2013, 12:09 AM
Quoted: 658 Post(s)
Liked: 434
TDP comparisons are completely irrelevant for the duty these chips will see in an HTPC
I don't know if it wasn't clear before, but if you compare the least efficient AMD mobo with the A10 5700 with the most efficient Intel mobo and an i7 3770k THEN the Intel would idle at lower wattage
Look at the links Aluminum posted, the guy in that blog built an i5-3570k to idle at 5.9 watts
Try and find any A10 that idles less than 2 times that
post #22 of 23 Old 01-10-2013, 02:11 AM - Thread Starter
allanmb's Avatar
I don't know if it wasn't clear before, but if you compare the least efficient AMD mobo with the A10 5700 with the most efficient Intel mobo and an i7 3770k and the Intel would idle at lower wattage
I understand that TDP is not the only indication of a low power build. I had a look at the links provided and I am not willing to go to those extents of soldering the motherboard. I would also like a larger motherboard as I have a couple of TV capture cards to attach, so mATX is the smallest I would be willing to go to.
allanmb is offline
post #23 of 23 Old 01-10-2013, 08:06 AM
SlantNGo's Avatar
If you're looking for a low-power micro ATX motherboard to pair with the A10-5700, I recommend the GIGABYTE GA-F2A75M-D3H. If I recall correctly, Silent PC Review found that it idles a few watts lower than the ASUS A85 chipset mobo.
allanmb likes this.
SlantNGo is offline
Reply Home Theater Computers
