Budget Laptop -- Glitch-Free HD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-09-2013, 12:50 PM - Thread Starter
dschmelzer's Avatar
Hi All--
My sister would like to get a budget laptop, but would still like to be able to stream Netflix in HD and perhaps other HD files as well.
What is the current state of play on hardware HD decoding on the integrated graphics chipsets? Do you need an HD 4000, strictly speaking?
Dan
dschmelzer is offline
post #2 of 10 Old 01-09-2013, 01:45 PM
Tiddles88's Avatar
Liked: 24
HD 2500 is sufficient. I'd take a 1080p film on USB along with VLC portable and test some laptops out. The newish Pentiums should have enough grunt. Celeron, uncertain.
Edit: Budget laptops are probably 1366x768 so 1080p is overkill, but if it plays 1080p, then it will play anything HD.
Tiddles88 is offline
post #3 of 10 Old 01-09-2013, 05:48 PM
jeffkro's Avatar
Yup, cheap laptops don't come with high res screens. You might as well just go with a pentium or celeron chip.
PS I'm all for cheap laptops because they get dropped, stolen, lost, etc.
This is the cheapest laptop on newegg with a 1080p screen:
http://www.newegg.com/Product/Product.aspx?Item=N82E16834127831
jeffkro is offline
post #4 of 10 Old 01-10-2013, 06:37 AM - Thread Starter
dschmelzer's Avatar
Thanks for your thoughts. So HD2500 and HD4000 are sufficient. What about HD3000 and HD4500? Also, am I recalling correctly that the Atoms still don't have the hardware decoding horses?
Dan
post #5 of 10 Old 01-10-2013, 07:23 AM
jeffkro's Avatar
I would avoid atom laptops. The intel celeron 847 is lowest you should go and still expect decent performance.
jeffkro is offline
post #6 of 10 Old 01-10-2013, 08:46 AM - Thread Starter
dschmelzer's Avatar
As I understand it, the Celeron 847 has an HD 2000 built-in. Is the HD 2000 sufficient?
Saw that the Acer C7 chromebook has the Celeron 847. Don't think it can boot Windows, unfortunately.
Dan
post #7 of 10 Old 01-10-2013, 09:17 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
Celeron 847 will run around 85-90% CPU streaming Netflix HD. So, it will do it but it gets pretty warm. (This was my experience testing the desktop form of the 847).
1080p file played through WMC, the CPU was under 20% and things ran cool and quiet.
XBMC's internal renderer in Windows was a no-go. You get macroblocking with DXVA on and the CPU couldn't handle it with it turned off. If you're willing to launch an external player though it goes back to the 2nd bullet above.
StardogChampion is offline
post #8 of 10 Old 01-10-2013, 09:49 AM - Thread Starter
dschmelzer's Avatar
That sounds plenty good enough for her purposes. Thanks for the report.
It would be great to be able to boot to Windows on that $200 Chromebook...
Dan
post #9 of 10 Old 01-10-2013, 03:24 PM
tomandbeth's Avatar
Would the OP or "An interested bystander" be able to stream 1080 withone of the Tablets
Let's say a 7 inch offering from Apple or Samsung?
tomandbeth is offline
post #10 of 10 Old 01-28-2013, 08:51 AM - Thread Starter
dschmelzer's Avatar
It looks like the Celeron 847 is getting somewhat long in the tooth. Is there any similar processor with a lower TDP than the Celeron 847's 17W, or will we need to wait until Q2?
Dan
Reply Home Theater Computers
