Which codecs for an old Pentium 4?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-09-2013, 02:36 PM - Thread Starter
Litos001's Avatar
Hí, i'm new here. xD
I found this forum trying to find a solution to my problem.
I have an old Pentium 4 witch an ATI x700 Pro Graphic card.
I've allways used k-lite codec pack to watch all my videos, included mkv's but I have seen that there are better solutions. However I don't know which one will be better for my configuration.
What do you think i have to install???
Lav filters? ffdshow? madVR whith lav filters?
Could you help me with this?
Greetings and thanks in advance
Litos001 is offline
post #2 of 8 Old 01-09-2013, 02:41 PM
Tiddles88's Avatar
Liked: 24
The bin. An Intel G550 is $35 at Microcentre, $45 elsewhere and is twice as fast as that CPU and GPU and uses half the power.
Tiddles88 is offline
post #3 of 8 Old 01-09-2013, 03:50 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
A P4 would be painfully slow as an HTPC. If you are on a budget, take Tiddle's advice but you're going to need a MoBo and some RAM and quite possibly a new HDD or SDD if you can squeeze it in. Add in the OS and you're up to $400 maybe.
If you cannot swing that does your mother board have PCIx slots or is it only AGP? If it has the former you may be able to use a newer graphicx card but I feel you'd be throwing good money after bad.
To answer your question, I recommend un-installing K-Lite and using Shark007. What OS and player are you using anyhow?
Sammy2 is offline
post #4 of 8 Old 01-09-2013, 10:47 PM
gonzo90017's Avatar
Quoted: 43 Post(s)
I recommend you use SAF Codec pack. The unlocked version will give you access to additional codecs that might work better on older hardware.
gonzo90017 is offline
post #5 of 8 Old 01-09-2013, 11:16 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Add Radeon HD 6450 (as low as $30) that supports hardware decode acceleration for MPEG2 / VC-1 / H.264, so P4 should be good. Uninstall all codec packs. Install LAV Filters, that's all what you need, as well as MPC-HC.
But I think it's time to upgrade your system.
renethx is offline
post #6 of 8 Old 01-10-2013, 02:11 AM - Thread Starter
Litos001's Avatar
First i tell you, this PC is my Mom's PC which use occasionally to whatch some movies or series or some navigation on the internet, so i will not upgrade it. xD
The PC configuration is:
Pentium 4 3Ghz
X700 Pro Graphoc card Pcie
2Gb Ram
500 GB HD
S.O: Windows 8 64bit
So, should i install only Lav Filters, to reproduce all king of formats in the best quality?
I think codec packs are not the best solution.
Thanks in advance.
Litos001 is offline
post #7 of 8 Old 01-10-2013, 02:43 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
LAV Filters is the only filter set you will need (in most cases).
Your system can play most SD contents and MPEG-2 HD contents, but it can't play VC-1 / H.264 HD contents because neither CPU nor GPU can decode VC-1 and H.264 fast enough.
renethx is offline
post #8 of 8 Old 01-10-2013, 02:53 AM - Thread Starter
Litos001's Avatar
Thanks. You're ritght, i've be able to play some HD in 720p content with normal framerate which is all i need, but 1080p files is really imposible to play normally, but it doesn't matter to me.
I'll try Lav Filters then, thanks.
Litos001 is offline
Reply Home Theater Computers
