Logitech Dinovo Mini - Change volume on tv or receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-10-2013, 10:00 PM - Thread Starter
Chriscorv58's Avatar
Quoted: 122 Post(s)
Liked: 82
I ended up buying a Logitech Dinovo (usb) to pair with my HTPC, works great for scrolling around in XBMC and basic web surfing. It has many "short cut" keys on it for powering off a TV or AVR, volume/channel changing. I just dont know where to being to get this to turn off my tv or control its volume. My TVs(samsung 6150) and receivers(denon 3312) volume and power off are paired using anynet+. so if i can control one im set on both. Any ideas from the experts? Thanks in-advance
Sony 940c 75" Display, Marantz AV8801, HTPC, JTR 215RM Mains & JTR 210RM Center, DIY Surrounds, Crown Xti & Cdi Amps, Seaton Submersive HP+ Master and Slave.
Chriscorv58 is offline
post #2 of 9 Old 01-10-2013, 10:50 PM
ajkrishock's Avatar
Quoted: 76 Post(s)
Liked: 33
Unless there's a new version of the diNovo, yours and mine are Bluetooth. They shouldn't be able to control anything but your HTPC. you'd need Infrared for control of the AV devices. If you use yours to turn your TV on and off, I'd love to know how you do it.
ajkrishock is offline
post #3 of 9 Old 01-11-2013, 03:37 PM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
The Dinovo I have is some sort of little USB adapter, like the majority of the wireless keyboards and mice use
post #4 of 9 Old 01-11-2013, 04:13 PM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
Right. That plugs into your HTPC. How is that supposed to control your TV or receiver?
lockdown571 is offline
post #5 of 9 Old 01-11-2013, 05:49 PM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
Wasn't sure if there was any anynet+ software I could install on my PC since they are all connected via hdmi
post #6 of 9 Old 01-11-2013, 07:00 PM
Quoted: 36 Post(s)
Liked: 87
Is anynet+ a form of HDMI-CEC? I don't think any PC has HDMI-CEC support out of the box. FYI, it is possible to add HDMI-CEC to an HTPC using this, which is supported by the latest version of XBMC. Whether this can be used to control your TV and Receiver with your Dinovo mini I'm not entirely sure. Might be worth looking into.
post #7 of 9 Old 01-11-2013, 07:10 PM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
Wow, it sounds like that might do the job! Thanks!!
post #8 of 9 Old 01-11-2013, 07:30 PM
Quoted: 36 Post(s)
Liked: 87
If you decide to give it a try, please report back! I also have Dinovo mini, as do many others on this forum, and I would love to know if it can control my TV/receiver!
post #9 of 9 Old 01-11-2013, 08:50 PM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
i'll order one up on monday!
Reply Home Theater Computers
