Media Center Master - Manual update of entries - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-10-2013, 09:42 PM - Thread Starter
Greg_R's Avatar
I have some movies that are not listed in the IMDB or TheTVDB. I'd like to update the fields manually through Media Center Master but it seems that I can't view the entry unless something has been downloaded from a source of meta data. Does anyone know how this can be accomplished? I'm aware that I can manually create XML files and then edit but I'd prefer to avoid that.
Greg_R is offline
post #2 of 8 Old 01-16-2013, 05:18 PM - Thread Starter
Greg_R's Avatar
Does anyone know how to do this?
Greg_R is offline
post #3 of 8 Old 01-16-2013, 05:24 PM
Catalytic's Avatar
Quoted: 14 Post(s)
I don't, but I have subscribed to the thread because I'm about to need to know how to do this, too. How do you manually create an XML file? (I'm about to start on the DVDs I set aside while I was ripping because they aren't on imdb, eek!)
Catalytic is offline
post #4 of 8 Old 01-16-2013, 05:39 PM
hdkhang's Avatar
Not sure if there is an easy solution out there with MCM (I know some other metadata software allows this), but just to throw a suggestion out there. Could you try grabbing an existing metadata file from another movie changing the title, put it in the directory for your movie and make some changes that way? I guess you can set the values to some defaults and save that metadata file somewhere to be used for any future instances.
hdkhang is offline
post #5 of 8 Old 01-16-2013, 05:56 PM
LastButNotLeast's Avatar
Quoted: 1793 Post(s)
Liked: 1404
From MCM, select the movie you want to edit and click on the "Metadata" tab. The fields will be blank. Enter the information you want, and click "Save" (I hate to tell you how often I've left out that last step!).
After you update Media Browser, the info will appear there.
You may need to update that movie manually (the double arrow icon at the bottom of the vertical menu on the left) before the info appears.
You may also want to "lock" the metadata so it doesn't get erased accidentally.
Catalytic likes this.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #6 of 8 Old 01-16-2013, 05:58 PM
Catalytic's Avatar
Quoted: 14 Post(s)
Thank you!
post #7 of 8 Old 01-17-2013, 11:36 AM - Thread Starter
Greg_R's Avatar
Hmm. I should have mentioned that I already tried this... maybe something is corrupted. Let's say I have 2 movies, movie A has pulled metadata and movie B was not found. Movie A was selected (either to finish editing or to view) and then I click (from the movie list) on movie B. Movie A's metadata is still in the metadata window.
It sounds like I should take some screen shots and post on MCM's forum...
Greg_R is offline
post #8 of 8 Old 01-17-2013, 12:22 PM
Liked: 1404
I find that you sometimes have to close the program and re-open it after making some changes.
Since they update it every two days (or so it seems!), it may change depending on the particular version you have.
Good luck.
Reply Home Theater Computers
