HDHomeRun vs. Hauppauge WinTV HVR-2250 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-11-2013, 12:52 PM - Thread Starter
DiGiTY's Avatar
I built a system with an Hauppauge WinTV HVR-2250 and it works beautifully and all, but I'm now considering a HDHomeRun (US) to consolidate to cut back on running full computers for one function. Are there any features or niceties I'll be missing by replacing my HVR-2250 with the HDHomeRun?
DiGiTY is offline
post #2 of 8 Old 01-11-2013, 01:08 PM
vladd's Avatar
Liked: 39
2250 will tune analog stations and the HDHR will not. They both tune digital ATSC/ClearQAM stations.
vladd is offline
post #3 of 8 Old 01-11-2013, 01:13 PM - Thread Starter
DiGiTY's Avatar
What about recordings? Where are they stored?
DiGiTY is offline
post #4 of 8 Old 01-11-2013, 04:48 PM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
They're generally stored on the PC that has the DVR app installed. If you're using Windows Media Center it will add the HDHR tuners to the pool after installing the HDHR software and running the TV signal setup in Media Center. You specify which drive you want to use for recordings and MC will automatically create a folder for you. If you're sharing the HDHR with multiple PCs you need to install the HDHR software on each of them and set up Media Center on them as well.
captain_video is online now
post #5 of 8 Old 01-11-2013, 05:16 PM - Thread Starter
DiGiTY's Avatar
So there's no centralized storage where all frontends can access the same recordings?
DiGiTY is offline
post #6 of 8 Old 01-11-2013, 05:19 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
these are merely tuners, not dvr boxes.
Foxbat121 is online now
post #7 of 8 Old 01-11-2013, 06:01 PM - Thread Starter
DiGiTY's Avatar
Gotcha. They're dual tuners, correct? Record two shows at once?
DiGiTY is offline
post #8 of 8 Old 01-12-2013, 08:18 AM
Quoted: 510 Post(s)
Liked: 336
In WMC, you can set up your Recorded TV folder as a shared folder under Media Libraries. If you have multiple PCs that record TV, you can add their Recorded TV folder to the media library as long as you have set up the sharing parameters in Windows. When you open up your Recorded TV folder, all recordings from the other PCs will appear and can be accessed as if they were in one location. If you're recording OTA broadcasts or copy freely programs on FIOS or digital cable, all recordings can be shared with other PCs. However, if any recordings have the copy once flag then they can only be played back on the PC that recorded them.
Reply Home Theater Computers
