Boot up time is more than 5 minutes.. Wanna help me reduce it? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 58 Old 01-13-2013, 10:24 AM - Thread Starter
AnthonyB's Avatar
Originally Posted by Ruiner View Post
How long to get into safe mode?
Back in XP days there was a third party utility that would track and time each service, driver program at startup to allow cleanup.
Happen to remember the name?
AnthonyB is offline
post #32 of 58 Old 01-13-2013, 11:37 AM
mdavej's Avatar
Quoted: 2276 Post(s)
Liked: 992
May be talking about BootVis. But if not, that's something to try as well.
mdavej is online now
post #33 of 58 Old 01-13-2013, 11:39 AM
Ruiner's Avatar
Yeah that's probably it.
Ruiner is offline
post #34 of 58 Old 01-13-2013, 11:42 AM
onlysublime's Avatar
Quoted: 910 Post(s)
Liked: 1483
SSD with Windows 8. that's a wicked combo for fast boot times.
onlysublime is offline
post #35 of 58 Old 01-13-2013, 11:44 AM
kapone's Avatar
Quoted: 260 Post(s)
Liked: 209
or...a correctly configured system for S3 sleep. Even faster than SSD and Windows 8. smile.gif
kapone is offline
post #36 of 58 Old 01-13-2013, 11:47 AM
Quoted: 910 Post(s)
Liked: 1483
Originally Posted by jeffkro View Post
5 minute boot? Something is wrong, I sure wouldn't clone it.
with a HDD and a fully loaded Windows 7 (meaning, all the apps you install and which have startup components), 5 minutes is possible. My fully loaded Windows 7 got me to the desktop pretty fast, but it just kept loading and loading so the desktop was sluggish while things were still loading in. If I waited until it was fully loaded, the time would be over 3 minutes.
going to Windows 8 was a nice improvement with a HDD. you get to the desktop in no time but it finishes much faster loading everything in. the only time Windows 7 is close is when both Windows 7 and 8 systems are close to bare. start installing all the programs you use in your normal workflow and Windows 7 starts to get longer and longer to boot. But the SSD is probably the best upgrade you can do to any system. Better than going from 4 GB to 8 GB. Better than upgrading your graphics card.
post #37 of 58 Old 01-13-2013, 12:32 PM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
Originally Posted by assassin View Post
I just threw together a build from a bunch of leftover parts this morning.
H67 ITX motherboard, G530 CPU, Samsung 840 120GB SSD, 4GB RAM, Win 7 Ultimate. My boot time is easily under 10 seconds.
I think my HTPC takes longer than that to get past the bios screen. redface.gif
Karyk is offline
post #38 of 58 Old 01-13-2013, 01:15 PM
Quoted: 910 Post(s)
Liked: 1483
yeah, I highly doubt you can cold boot a complete Windows 7 with apps in under 10 seconds. just the BIOS screens alone takes a few seconds.
post #39 of 58 Old 01-13-2013, 01:27 PM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
I will actually time it once XBMC is finished updating the movie collection.
assassin is offline
post #40 of 58 Old 01-13-2013, 02:03 PM
captain_video's Avatar
Quoted: 529 Post(s)
Liked: 341
Try it with a SATA III SSD and compatible motherboard and it might surprise you. I just put together a new IvyBridge build with a SATA III SSD and the boot time is ridiculously fast. I believe most BIOS settings these days allow you to configure it for fast boot that bypasses the POST screen.
captain_video is offline
post #41 of 58 Old 01-13-2013, 02:06 PM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
18 seconds now with everything loaded up. Just timed it with a stopwatch.
assassin is offline
post #42 of 58 Old 01-13-2013, 02:18 PM
Quoted: 910 Post(s)
Liked: 1483
what's installed on the system? is this only an HTPC setup? or do you do work on this system?
the fastest I ever got Windows 7 to boot with SSD (including the post screens and BIOS) is around 17-25 seconds and that was because it was freshly installed. once I loaded it down with all my usual programs, it was much longer.
post #43 of 58 Old 01-13-2013, 02:54 PM
assassin's Avatar
Quoted: 172 Post(s)
Liked: 276
Its a test machine. I have a whole bunch of stuff installed while testing some new hardware (some new, some old).
assassin is offline
post #44 of 58 Old 01-13-2013, 10:04 PM
duff99's Avatar
A lot of it depends on the motherboard. My HTPC with a ASRock Z-77 board and a vertex 4 SSD boots at least as fast as Assassin's system. It's crazy fast. My Gigabyte builds on the other hand tend to take much longer to get through post so it takes longer for the boot. It's my experience that newer boards will boot faster than older ones. My new main system with a Gigabyte board boots about three times faster than my old one.
duff99 is offline
post #45 of 58 Old 01-14-2013, 05:20 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
AsRock 7zz boards boot the fastest....
Mfusick is offline
post #46 of 58 Old 01-14-2013, 08:04 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
First and biggest improvement in Boot times is SSD. It's just way faster.
Second would be the MOBO. Some mobo's have lots of chips or extras that slow down boot. Example: I have an Asus Z68 Deluxe on my desktop. It's much slower booting than my Asrock Z77 in my HTPC. Mostly because it has a built in RAID SATA 3 Controller that loads adding a screen to the time. It also has Dual lan. Last, the Asrock boards in general are amongst the fastest at rebooting and they also use the FastBoot feature.
Third (and this is for 5 minute boot times) is the software. How clean your install and registry is. If there is any conflicts or errors, and what must load up or install.
Sounds like you could do all three to shorten your boot to under 15 seconds if needed.
You might have a bad sector on your HDD that delays the booting up.
Swapping to SSD should make a huge impact on your boot time. Certainly under 30 seconds without more tweaks.
Mfusick is offline
post #47 of 58 Old 01-14-2013, 08:56 AM
lsilvest's Avatar
The suggestion you were given of disabling all startups and then putting them back one at a time until you find the culprit that is slowing your startup. If you disable all you find in msconfig and it still doesn't speed things up, try going in to your registry editor and search for "RUN" and it will show everything that is loading. You will have to keep pressing f3 key to find all instances in the editor. I have seen things starting that don't show in msconfig.
Those that told you an SSD wouldn't solve the problem completely are correct as 5 min is ridiculous. I am just putting together a system for my grand daughter with old parts and the boot drive is an 80GB 7200 SATA drive and it boots in a reasonable amount of time.
lsilvest is offline
post #48 of 58 Old 01-14-2013, 09:18 AM - Thread Starter
AnthonyB's Avatar
I have a sneaking suspicion it has something to do with my network. It takes forever for circle in the tray to just turn to a monitor (network connection)..
Will try to update drivers and see how that works
AnthonyB is offline
post #49 of 58 Old 01-14-2013, 09:18 AM - Thread Starter
AnthonyB's Avatar
AnthonyB is offline
post #50 of 58 Old 01-14-2013, 09:26 AM
drtdiver's Avatar
That is what my pc was doing with recordedtvhd installed. Changed recordedtvhd service to delayed start issue went away.
drtdiver is offline
post #51 of 58 Old 01-14-2013, 11:04 AM - Thread Starter
AnthonyB's Avatar
Everything I've done hasn't helped.
I'll defrag the hard drive and call it a day. The hard drive is just not going to boot up the computer any faster.
AnthonyB is offline
post #52 of 58 Old 01-14-2013, 11:08 AM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
I wasn't one of those that said that, but I would not agree with those who said that. It depends on what the problem is. On my older desktop having an SSD installed probably would cut 3 minutes off the boot time if I had my two email clients and a browser set as startup items. Before the SSD, trying to launch those three programs while the other startup programs were loading would stall my system to a crawl. After I can click all three right after I see the desktop, and all three will pop right up, including Outlook with a large PST file.
Karyk is offline
post #53 of 58 Old 01-14-2013, 11:34 AM - Thread Starter
AnthonyB's Avatar
I also increased the size of the page file. Doubt that will do much but it was under the windows recommended size.
Would like to find a program that can defragment the page file too. Hard drive will be replaced by SSD very soon, too much of a bottleneck. Might upgrade the ram too, 4 GB isn't enough anymore.
AnthonyB is offline
post #54 of 58 Old 01-14-2013, 11:54 AM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
Are you running a 64 bit OS?
Karyk is offline
post #55 of 58 Old 01-14-2013, 12:23 PM - Thread Starter
AnthonyB's Avatar
Yes
AnthonyB is offline
post #56 of 58 Old 02-07-2013, 07:16 PM - Thread Starter
AnthonyB's Avatar
Update on this thread. I upgraded to an i3-3220 with an ocz vertex 3 drive. It is super fast and boots up extremely fast.
One thing about things slowing down boot times, I installed an update for tmt and all the sudden the computer boots a little slower.
So, it just goes to show, all kinds of things will slow a boot.
I haven't installed a single update. It's at sp1 and it's going to stay there.
Restoring to a backup tomorrow. Should be done with installing software after that.
I can hit the restart computer in the start menu and be back to Windows Media center in under 30 seconds.. I'll trade speed for updates any day.
AnthonyB is offline
post #57 of 58 Old 02-08-2013, 06:26 AM
bryansj's Avatar
Quoted: 1420 Post(s)
Liked: 645
Remove the TMT server from startup. That is useless IMO.
bryansj is online now
post #58 of 58 Old 02-08-2013, 07:38 AM - Thread Starter
AnthonyB's Avatar
I did.. Actually it's when the orb is strobing on the " Starting Windows" screen
AnthonyB is offline
Reply Home Theater Computers
