5.1 set up with htpc - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-12-2013, 01:55 PM - Thread Starter
kwed's Avatar
I purchased an hp slimline s5-1400t to run my antenna through it. I have the computer hooked up to my sharp aquos via hdmi. Then an optical audio canle out to my receiver. Works fine except I realized now is that the computer won't detect the 5.1 speaker set up only stereo. I have tried hooking a 3.5 mm jack to my tv in then out via optical but it still doesn't detect it. Any ideas?
kwed is offline
post #2 of 7 Old 01-12-2013, 06:48 PM
sitlet's Avatar
Quoted: 16 Post(s)
The optical out port on your tv only outputs 5.1 from the tv's internal tuner. Anything connected to it, the tv will only passthrough 2 channel stereo. You will have to connect the laptop directly to the receiver via hdmi or optical.
sitlet is offline
post #3 of 7 Old 01-12-2013, 07:09 PM - Thread Starter
kwed's Avatar
Yeah that's what I was thinking too. Too bad there was no optical out on my pc. Need a new sound card I guess. Thanks.
kwed is offline
post #4 of 7 Old 01-12-2013, 11:03 PM
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
Do you have a SPDIF coax output on the PC? If so, I seem to recall seeing coax to optical adapters.
Mike99 is offline
post #5 of 7 Old 01-13-2013, 09:49 AM - Thread Starter
kwed's Avatar
I don't thinking so what does that look like?
kwed is offline
post #6 of 7 Old 01-13-2013, 01:35 PM
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
The SPDIF coax output is a standard RCA phono jack.
Mike99 is offline
post #7 of 7 Old 01-13-2013, 01:45 PM
Andrew Hornfeck's Avatar
Quoted: 31 Post(s)
Why not run the HDMI to the AVR then from AVR to Display? That's the preferred method. Usinf SPDIF to the AVR is also acceptable assuming you have one... I looked online and finding the specs for your s5-1400t ain't easy... maybe you can post a pic of the rear looking for an optical out or an RCA coaxial (Digital) out.
BTW, you can usually find a $20 USB to SPDIF out dongle is you find you don't have one on the system and can't run to the AVR directly w/HDMI
Andrew Hornfeck is offline
Reply Home Theater Computers
