Trailers on DVD - AVS Forum | Home Theater Discussions And Reviews
Old 01-13-2013, 12:45 PM - Thread Starter
MrPictureman's Avatar
As I go through searching to update missing or poor quality movie trailers I can't help but think that I must have that particular trailer on one of my 1000+ dvd's. But where to search for it on which DVD? My question, is there a reference some where that shows what trailers were put on what dvd. If I had such a thing it would be easy to fine said trailer in my collection or to verify that I do not have it?
MrPictureman is offline
Old 01-13-2013, 01:19 PM
sitlet's Avatar
Anyway, not sure if you're going to find anything like that. DVD's, even the same title, will have different trailers depending on when they are released. Studios may put newer trailers on the same title after it's been out for a few months.
sitlet is offline
Old 01-13-2013, 01:26 PM - Thread Starter
I understand that however I would assume they would be the same with the same barcode so I would think it would be doable but a lot of work?
Old 01-14-2013, 08:49 AM
sitlet's Avatar
Umm, yes it would be a LOT of work, and again, not sure why you would want to do it.
sitlet is offline
Old 01-14-2013, 09:10 AM
Dark_Slayer's Avatar
Quoted: 657 Post(s)
Liked: 434
Nothing I know of exists
A good bet would be to look for something released earlier in the same year from the same studio
Movie studios don't cross-trailer their DVDs too often
I think you'd still have to pop it in and watch
Even sites like bluray.com, which tell you the audio/video formats of extra features don't list the bundled trailers. If you find a place that has that detailed of review information on DVDs please pass it on
Dark_Slayer is online now
Old 01-14-2013, 03:25 PM - Thread Starter
Thanks for your help if I come accross something I will let everyone know. Trailers are handy to have especially if you have a lot of dvd's and forget what the movie was about you can do a quick trailer watch to see if it's something you want to watch at the moment.
Old 01-15-2013, 08:50 AM
sitlet's Avatar
So you would rather search through your master list, then try to find the dvd, put it into the dvd player, and skip through to the right trailer? Rather than just youtube the trailer?
sitlet is offline
Old 01-15-2013, 08:33 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
IMDB the trailer. They have pretty HQ and if you get a good recorder like Action! you can make pretty good copies of them. Here's some crappified by YouTube HD Action! recording: http://www.youtube.com/watch?v=STCKwxzL3VM
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Old 01-16-2013, 06:48 AM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
much easier way to grab youtube vids, use jdownloader.
copy paste the youtube url and it will grab and let you select which downloads you want, flash, mp4, webm, and each of those in different resolutions.
aliaskary77 is offline
Old 01-16-2013, 09:23 AM
Quoted: 657 Post(s)
Liked: 434
MCM will fetch trailers from Yahoo, Youtube, IMDB, and Apple
I think the OP (since they stated having over 1000+ DVDs) has run into this problem for a small portion of their collection. Some older movies and foreign films don't have a decent trailer available in youtube or imdb. Sometimes the only youtube hit you can find is pretty grainy
Again, this is pretty uncommon, but it would be rather annoying to know that it sits somewhere on a huge dvd collection
Old 01-16-2013, 09:35 AM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
Another good source to download trailers: Dave's Trailer Page
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
Old 01-17-2013, 11:42 AM - Thread Starter
Dark_Slayer you hit the nail on the head perfectly Shark I will also check your link
