Help me find a replacement external OEM PSU - AVS Forum | Home Theater Discussions And Reviews
Old 01-13-2013, 03:47 PM - Thread Starter
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
I know the PSU is 19v and 180watt.
Does the shielding around the pins on this look like a match?
http://www.ebay.com/itm/180W-19V-9-5A-AC-POWER-ADAPTER-/200830707912?pt=US_Autographs&hash=item2ec27168c8
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
Old 01-14-2013, 06:26 AM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
What's it used for? I can't tell from your photos. Try searching on ebay or do a google search. You can usually find aftermarket PSUs like the one shown in your photo on ebay for much less than what the manufacturer would charge.
captain_video is offline
Old 01-14-2013, 07:37 AM - Thread Starter
Quoted: 648 Post(s)
Liked: 426
It's a Niveus Vail. I won it ridiculously cheap on ebay and think it will work out well in my bedroom if I can find a proper PSU for it.
Old 01-14-2013, 11:55 AM
Quoted: 510 Post(s)
Liked: 336
The power connector appears to be a standard 4-pin mini-DIN connector, similar to a S-Video connector without the keying tab in the center. Take a look at the first comnnector on the left on this wiki site:
http://en.wikipedia.org/wiki/Mini-DIN_connector
If the PSU identifies the pinouts, voltages, and amperages then you should be able to find a generic PSU similar to one used for a laptop and put it together yourself. Based on the fact that it has four pins instead of just two, I'm guessing it puts out two different voltages at different amperage ratings (probably 5VDC and 12VDC with ground pins for each). If you can't find a single PSU with dual voltages you could always use two separate PSUs tied together with one connector that plugs into the unit. It won't be as pretty, but it will be functional.
BTW, have you tried contacting Niveus to see what they'd charge for a replacement?
