NO SOUND through HDMI and Issues with Optical out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-13-2013, 05:56 PM - Thread Starter
jdastas's Avatar
Hello all,
Today has been a complete disaster with my HTPC. I've been running this machine for almost a year now with no issues at all. I use XBMC to play all my media and loved it. Today I decided to upgrade to the latest version of XBMC, The version is still in Beta, but it is a release candidate and should not have affected my computer the way it has. Here are the events as they unfolded.
- DL'd XBMC
- realized HTPC audio has stopped
- Checked other programs on HTPC to see if the audio works, NO AUDIO AT ALL even when program is close.
- connected optical cable to avr to see if it was an hdmi issue, I get audio back in regular windows programs but not while playing movie files like MKV using VLC.
- used system restore to revert back to a few days ago hoping this could fix my issue and I again can get audio from HDMI.
- Did not work,
I am thinking that my next step will be to do a fresh re-instal of windows, something I definitely dont want to do.
Any help would be greatly appreciated,
jdastas is offline
post #2 of 15 Old 01-14-2013, 01:54 AM
steelman1991's Avatar
Quoted: 211 Post(s)
Liked: 116
You did all this,checked in here, but didn't use the xbmc forums? - have a look at the sticky in the windows forum of xbmc about setting-up audio with the new Frodo builds. The audio engine has totally changed with the Frodo builds
steelman1991 is offline
post #3 of 15 Old 01-14-2013, 06:20 AM
balky's Avatar
Quoted: 227 Post(s)
Liked: 131
Did you run (or re-run) the windows audio setup tool in the control panel?
balky is offline
post #4 of 15 Old 01-14-2013, 06:50 AM
Quoted: 211 Post(s)
Liked: 116
Good shout
post #5 of 15 Old 01-14-2013, 01:02 PM - Thread Starter
jdastas's Avatar
Thanks for the reply, but like I stated. The problem started when I noticed XBMC not working properly. Unless I missed it in that thread, it still doesn't explain how the audio stopped for other programs on windows including VLC and WMC. Like I stated, I get no audio at all now... Not just on XBMC
jdastas is offline
post #6 of 15 Old 01-14-2013, 01:04 PM - Thread Starter
jdastas's Avatar
i'll try this again when I get home.
jdastas is offline
post #7 of 15 Old 01-14-2013, 01:06 PM
Quoted: 211 Post(s)
Liked: 116
Did you try Balky's suggestion? beat me to it
post #8 of 15 Old 01-14-2013, 01:09 PM - Thread Starter
jdastas's Avatar
I will when I get home from work...
Just to clarify, to run this I go to:
Control Panel --> "Sound" ?
Thanks again
jdastas is offline
post #9 of 15 Old 01-14-2013, 01:20 PM
Quoted: 211 Post(s)
Liked: 116
That's the one.
post #10 of 15 Old 01-14-2013, 09:11 PM - Thread Starter
jdastas's Avatar
okay, really weird I believe, but this is what I did as still did not get any sound. I uninstalled realtek audio drivers, restarted my computer and everything worked again. I now have sound from every program including xbmc. Only reason why I thought to do this is because in the xbmc forum regarding audio issues, it states to remove this driver and only use WASSAPI??? My issue with this is I don't believe with this set up I can get HD audio at all. Also I can see removing the realtek driver possibly improving audio in xbmc, but why would effect everything else on my computer as well?
jdastas is offline
post #11 of 15 Old 01-15-2013, 01:13 AM
Quoted: 211 Post(s)
Liked: 116
With xbmc, using WASAPI mode is the only way to achieve bit-prefect HD Audio, in passthrough mode. The introduction/inclusion of realtek drivers seem to produce all sorts of issues/conflicts. Better to stick with your cards proprietary drivers.
post #12 of 15 Old 01-16-2013, 10:24 AM - Thread Starter
jdastas's Avatar
Steelman,
Are you referring to a seperate sound card. Perhaps I am confused... Maybe I dont have WASAPI. What I have is an I5-2550K with an intel DH67GDB3 mb. I'm currently using the HDMI out. Is this a WASAPI set up?
jdastas is offline
post #13 of 15 Old 01-16-2013, 11:08 AM
Quoted: 211 Post(s)
Liked: 116
Originally Posted by jdastas View Post
Steelman,
I was (sorry I just assumed you were using a seperate card), but the same advice applies to using an integrated chip (use the propietary drivers). Your chip is perfectly capable of using WASAPI. Just make sure you set-up in accordance with the sticky thread at the top of the xbmc windows thread - also have a look here for some additiional advice http://wiki.xbmc.org/index.php?title=Windows_Settings_for_AudioEngine.
post #14 of 15 Old 01-16-2013, 10:37 PM - Thread Starter
jdastas's Avatar
Well I have given up for the time being. Wife and kids were getting frustrated with not being able to watch some of their stuff so I went ahead and hooked up the audio through optical. With that said, I am 95% positive I wont be able to do HD audio, oh well.
Thanks for the help guys
jdastas is offline
post #15 of 15 Old 01-17-2013, 12:43 AM
Quoted: 211 Post(s)
Liked: 116
Just to put your mind at rest - I can give you a 100% assurance that you won't get HD Audio through Optical - but it definitely is achieveable with your i5 chip. Appreciate the pressure for a working solution from others though.
Reply Home Theater Computers
