New TV broke GOM player - AVS Forum | Home Theater Discussions And Reviews
Old 01-13-2013, 05:59 PM - Thread Starter
jeffkro's Avatar
Any ideas on how buying a new TV would cause a specific player to stop playing well. It use to play perfectly smooth, but now i get stuttering on DVD files. The same files play perfect in windows media player.
Llano A6 with win7 64bit
jeffkro is offline
Old 01-15-2013, 08:21 AM
Andrew Hornfeck's Avatar
Quoted: 31 Post(s)
Check your TV for how you should be connecting it - some are picky about which is to be used for a PC vs commercial player. Also, check your PC settings -- assure you're still on 60Hz... it could be the EDID of the TV told your PC to use 50Hz... I use the A6-3500 in my bedroom just fine!
Andrew Hornfeck is offline
