noob question... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-14-2013, 08:05 AM - Thread Starter
Nodollas's Avatar
I have decided to dive in to an htpc... I'm just starting to get a list together while reading here and other places to make sure I"m not disappointed in the end. The question to start off with is, the connection between my pc and my tv (through my av reciever)... is it as simple as hdmi out of the pc, hdmi in my reciever, hdmi out of the reciever to the tv? The reciever is a pioneer vsx 1018... if it makes any difference.
I know this is basic, please be patient with a greenie
Nodollas is offline
post #2 of 7 Old 01-14-2013, 08:14 AM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
is it as simple as hdmi out of the pc, hdmi in my reciever, hdmi out of the reciever to the tv? - Yup.
kapone is offline
post #3 of 7 Old 01-14-2013, 08:45 AM
monkeymania's Avatar
Agreed, it should be that simple.
For me, my Onkyo receiver hesitated a bit and caused about a 2 second delay with sound when changing channels, so I decided to go HTPC --> TV (HDMI), then TV--> Rec (optical audio). Problem fixed. I have since sold all my other input devices, so this really makes no diff for the user experience.
monkeymania is offline
post #4 of 7 Old 01-14-2013, 01:22 PM
lovekeiiy's Avatar
Liked: 30
yes, that simple to connect. you may have to tweak the resolution or something, but to get a picture, nope. Most newer TVs will be can be detected by Windows 7 or later without any problems.
lovekeiiy is offline
post #5 of 7 Old 01-14-2013, 01:50 PM - Thread Starter
Nodollas's Avatar
Cool.... I'm sure I'll be posting back. Thanks Guys
Nodollas is offline
post #6 of 7 Old 01-14-2013, 04:09 PM
psuKinger's Avatar
Quoted: 692 Post(s)
Liked: 188
Short answer: yes
But if you connect your equipment this way, you probably won't be able to work with your HTPC unless the AVR is on and tuned to the HTPC input. Without power to the AVR and the proper input selected, the signal won't travel to the HDTV, so you won't be able to see/manipulate your desktop until you turn the AVR on.
As long as that's ok with you, then the arrangement you've mentioned will work. I personally would prefer to have the option to use an AVR, but not required to do so... but my efforts to use an HDMI Splitter (to the HDTV and the AVR in parallel) have, to-date, been failures.
psuKinger is offline
post #7 of 7 Old 01-14-2013, 05:34 PM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
My Denon 4311 has a "passthrough" setting for HDMI, where that input is passed through, even if the AVR is off.
kapone is offline
Reply Home Theater Computers
