HTPC tuner help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-14-2013, 08:59 AM - Thread Starter
freekmccoy's Avatar
I'm looking to add a tuner card with the only use being to play my cable tv thru pc to projector.I only have basic cable (Suddenlink) and no cable box.Currently I have it running straight from wall to tv.I can pick up locals in HD this way but only on this tv. Will these come in using this tuner?:
http://www.ebay.com/itm/230899916779?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
freekmccoy is offline
post #2 of 2 Old 01-14-2013, 01:19 PM
lovekeiiy's Avatar
Liked: 30
Looks like it will work for you. Here's the support page on it: linky.
Your idea is very doable. I'm not familair with card. It's been around for over five years.
I'm just clear if you just looking to feed the PC the TV signal or more of house distribution. If so, I'm not sure that card will have enough tuners for your needs. Also, you'll probably get same the channels on the tuner card your TV gets from the pipe.
For $10, it's not a big financial commitment if it fails or doesn't work out as you plan.
lovekeiiy is offline
Reply Home Theater Computers
