Cablecard tuner dies when switching from TV to watch MKV in WMC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-14-2013, 09:15 AM - Thread Starter
StephenG99's Avatar
Just built my first HTPC last week and been really happy with it so far. The only issue I have is when I go to watch one of my local MKV's the tuners on my hauppauge WinTV-DCR-2650 all turn off (Comcast cable). Of course this is really annoying when I happen to be recording something. Generally to get the tuners back I have to restart WMC. My google fu is failing me on this one or worse I'm the only person to have encountered this. Anyone else seen this behavior?
StephenG99 is offline
post #2 of 7 Old 01-14-2013, 09:40 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 397
WMC does not natively support MKV playback. You must installed some codec packs. Some of the codec pack installer will break the Media Fundation feature of WMC (where your cable card programs are dependent on) out of box. So you need to provide some more details.
Foxbat121 is offline
post #3 of 7 Old 01-14-2013, 09:52 AM - Thread Starter
StephenG99's Avatar
oh yes, I installed the shark 007 codec packs and followed the install guide that has been posted here.
post #4 of 7 Old 01-14-2013, 12:21 PM
erickotz's Avatar
Liked: 30
I would recommend that you uninstall all codec packs and simply install an MKV splitter. For most, the splitter is enough, and doesn't introduce the issue that codec packs sometimes do.
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #5 of 7 Old 01-14-2013, 01:09 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
press [Reset All] in the Settings Application. (to return user settings to defaults)
some settings, such as the [x] SUGGESTED settings, disable Media Foundation.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #6 of 7 Old 01-14-2013, 01:38 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
+1. This is all I have on mine.
jdcrox is offline
post #7 of 7 Old 01-14-2013, 07:27 PM - Thread Starter
StephenG99's Avatar
Thanks for the reply Shark007 but I couldn't get it to work. Even uninstalled/reinstalled but WMC keeps dropping my tuners. Just running Haali splitter on it's own and everything is working ok now. Thanks for the tips guys!
Reply Home Theater Computers
