Getting Computer Video/audio to HDMI TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-14-2013, 07:54 PM - Thread Starter
FarmerCharlie's Avatar
I would like to use an old Dell 4600 WindowsXP computer to provide Internet HDMI video for my Samsung PN60E550 TV. The TV does not have an RGB input. The most straightforward approach would be to use one of the analog RGB to HDMI converts, such as the Monoprice 4629 for $35 or the Sewell SW-30008 for about $70. Alternatively, the computer has onboard analog RGB output and a spare AGP slot, but no PCI-E slots. Sound is important, and all the converters have inputs for RGB video plus audio. I'm not sure whether the AGP cards can include sound either directly or via an auxiliary audio input. A 2009 post to this forum mentioned the Radeon HD4650, but there was some question on how sound was handled. NewEgg has an HIS Radeon HD 4350 for $60, which would be about the same as the RGB-HDMI converters. The HIS WEB site says the card has "NATIVE HDMI output with digital 7.1 sound channels." If that works reliably, then that would be my choice.
I would appreciate any recommendations on which overall approach would be better, and whether the Radeon card would be a good choice.
FarmerCharlie is offline
post #2 of 4 Old 01-14-2013, 09:27 PM
rbmcgee's Avatar
Hi,
I'm perplexed.
1) I don't know what "internet hdmi" is,
and
2) You have a smart TV that can stream stuff from the internet directly into the TV via the apps built into the TV. No need for an htpc.
and
3) When you say "sound is important" is that a comment on A) I want to be able to hear things, or, B) I care about fidelity. If it's B), any of your options are lacking assuming the audio output is the TV.
Bob
rbmcgee is offline
post #3 of 4 Old 01-14-2013, 09:57 PM - Thread Starter
Originally Posted by rbmcgee View Post
Hi,
I'm perplexed.
Sorry. I meant video extracted from the Web through the computer and delivered to the receiver's HDMI input.
Have you ever used the remote on the Samsung "smart" TV to enter a UserID and password using the Samsung apps? It's about as kludgy as using a mile of wire to create a 5 microsecond time delay.
I mean that it is important that it work.
The audio output will be through a Yamaha surround sound receiver.
And thanks for the helpful suggestions.
post #4 of 4 Old 01-14-2013, 10:35 PM
rbmcgee's Avatar
Got it.
1) install 4350 into computer
2) specify audio output to use hdmi on pc
3) hdmi cable from pc to receiver
4) hdmi cable from receiver to tv
Bob
rbmcgee is offline
Reply Home Theater Computers
