Power Management - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-15-2013, 02:32 PM - Thread Starter
ncochran01's Avatar
I'm not sure if this has been discussed before:
I use my PC to record TV. It's also my primary gaming PC. Here's what I do:
I'm usually gaming on the first monitor (League of Legends or something on Steam) and watch TV in the other.
When I go to bed, I have to leave the PC running so my Xbox can watch my shows/live TV via Media Center. Then I usually get out of bed and turn my PC off so it's not running all night. Then I get up and turn it on before I go to work.
What I would like to do is find a piece of software (on the cheap or free side and is simple to use.) that will allow my to schedule my PC to shut off at X time and turn back on at Y time. I'd like to have it turn off earlier during the week and later on the weekend.
What usually happens is I shut it off at night and forget to turn it on before I go to work and miss some of my shows. I hate wasting energy and leaving it on all the time.
Any ideas?
On a side note, I have a Media Center PC remote for my PC. I'm not sure if I can shut down the computer using that. Or if there is an app for my Android phone that would allow me to turn my PC off and on. That's also an option.
ncochran01 is offline
post #2 of 8 Old 01-15-2013, 02:45 PM
macks's Avatar
Liked: 31
If you instead put your computer to sleep then whatever program you are using to record TV should be able to wake it. Usb mce remotes don't work with a pc that is completely powered off, once again it can work from sleep.
macks is offline
post #3 of 8 Old 01-15-2013, 06:42 PM
jhhoffma's Avatar
If you built your PC, the BIOS may have wake timers for turning the PC on a particular time from complete shutdown.
Any other approach will involve using S3 (suspend-to-RAM) mode. This is pretty common with modern hardware and you'd most likely want to use Wake-On-Lan (generic term) to wake up your PC and built-in windows power management to put it to sleep again. Windows 7 is pretty good about not entering sleep mode when files are being shared by another device, but there are always quirks.
It's a project for sure and there are a million different ways to set it up.
Depending on the configuration of your PC, you might also be able to use some software to lower it's power draw (via undervolting) while it is on as well, to further reduce energy usage, and lower heat generation.
For your PC silencing needs...check out www.silentpcreview.com
For your WHS needs...check out www.wegotserved.co.uk
jhhoffma is offline
post #4 of 8 Old 01-15-2013, 08:21 PM - Thread Starter
ncochran01's Avatar
I'm interested in the S3 stuff. You just blew my mind. The box I'm using is the HomeRunHD Prime, it's connected on the network. Can that use WOL?
how do I set up S3 mode?
post #5 of 8 Old 01-16-2013, 01:49 AM
step13's Avatar
Since getting your computer to sleep is new to you, I will give a brief summary to get you started. Search the web for details.
The first thing you should know is that you cannot always get your computer to sleep reliably. It may not wake at all, or some things may not work properly after the computer has been sleeping one or more times. Reliable sleeping needs the hardware and hardware drivers to work correctly. However, modern systems are much better, and there is a good chance they will work properly.
The Control Panel is used to configure how the computer sleeps. Go to: Control Panel > Hardware and Sound
Then under “Power options”, click on “Change when the computer sleeps”
There are several power states:
Off: Zero power used. The computer is unplugged, the battery is removed, or the switch at the back of the computer is flipped.
Soft Off: Usually 1-5 watts used. The computer is shut down. Most of the hardware is powered down, but the power switch works. A USB remote receiver cannot wake the computer from this state; you need a remote receiver that is connected to the motherboard’s big power cable. A few motherboards have special headers that can also be used. An example of a remote receiver that is connected to the power cable is:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811999191
(Note: I have not tested this remote receiver. My HTPC case has this functionality built in.)
Hibernate: Usually 1-5 watts. This state is the same as Soft Off, except that when it hibernates, the computer’s entire running state is written to disk before it shuts down. When the computer is wakes, it reads this data and restores it to the state (running programs and all) that it had before hibernating. Waking from hibernation requires the same special hardware as Soft Off.
Sleep (S3): A bit more power than Soft Off or Hibernation. In Sleep, more of the system is powered. (A power outage while sleeping will crash the system.) The RAM stays on, so the computer can wake in just a few seconds. USB remote receivers, keyboards, and mice can wake the computer, if the power setting in their drivers is set correctly. Wake on Lan (WOL) can also wake the computer. To do this you will need to set the network driver to wake on a magic packet. You may also need to change a BIOS setting.
Hybrid Sleep: The same power as Sleep (S3). This is the same as Sleep (S3) except that it also saves the running state to disk, just like in hibernate. A power outage while sleeping will not crash the system, instead it will wake like it wakes from hibernation.
P.S. There are devices that can turn other equipment on or off depending on the computer’s power usage; they can power the equipment off when the computer is sleeping, and power it on when the computer is awake. I do not know if this could be used with an XBOX.
step13 is offline
post #6 of 8 Old 01-16-2013, 11:23 AM
jhhoffma's Avatar
Don't forget that the BIOS also has to be configured to work with the right sleep settings.
Unfortunately, you haven't posted any info on your HTPC, so I can't really help you setup S3. However, there are plenty of useful info out there for doing so, just google "enable S3" or something similar.
I don't think the HD HomeRun is capable of sending out WOL packets. However, if you configure your HTPC properly, it should come out of sleep mode on it's own for recording and then follow the selected Power Plan to go back to sleep (after 30, 60, etc minutes of inactivity -> Sleep/Shutdown/etc)
jhhoffma is offline
post #7 of 8 Old 01-19-2013, 08:36 AM - Thread Starter
ncochran01's Avatar
Here are some details regarding my machine as requested.
1 x Case CoolerMaster HAF 922 Gaming Case - Black
1 x iBUYPOWER Labs - Internal Expansion iBUYPOWER Internal USB Expansion System + Bluetooth Module
1 x Processor [= Quad Core =] AMD Phenom™ II X4 975 Black Edition Quad-Core CPU
1 x Processor Cooling Liquid CPU Cooling System [AMD] - [Free Upgrade] Standard 120mm Fan
1 x Memory 16 GB [4 GB X4] DDR3-1600 Memory Module - Corsair Vengeance
1 x Video Card NVIDIA GeForce GTX 560 - 2GB - Single Card
1 x Motherboard Gigabyte GA-870A-USB3 -- AMD 870 w/ 2x PCI-E 2.0 x16
1 x Motherboard USB / SATA Interface Motherboard default USB / SATA Interface
1 x Power Supply 750 Watt -- Thermaltake TR2 TRX-750M
1 x Primary Hard Drive 64 GB Kingston SSDNow V100 Series SSD - Single Drive
1 x Optical Drive 24X Sony Dual Format/Double Layer DVD±R/±RW + CD-R/RW Drive - Black
1 x Meter Display NZXT Sentry 2 Touch Screen Fan Controller & Temperature Display
1 x Sound Card 3D Premium Surround Sound Onboard
1 x Network Card Killer Xeno Pro Gaming Network Card
1 x Operating System Microsoft Windows 7 Professional + Office Starter 2010 (Includes basic versions of Word and Excel) - 64-bit
I have 3 additional drives for storage.
post #8 of 8 Old 01-19-2013, 10:58 AM
mdavej's Avatar
Quoted: 2131 Post(s)
Liked: 942
My solution is very simple. My HTPC is set to sleep after 3 minutes, but stay awake while using media center. I don't ever turn it off with my remote, I just let it go to sleep. Whenever I send any IR command to it or use an Xbox extender, it wakes up automatically. It also wakes for recordings and guide updates.
You should be able to set up sleep in control panel - power options - advanced, provided sleep is enabled in your bios. You'll also want to turn on the option to have your PC turn back on after a power failure.
mdavej is offline
Reply Home Theater Computers
