DTS-HD master audio not working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-18-2013, 04:55 AM - Thread Starter
Ahvir's Avatar
Hello!
I've had an Onkyo HT-R380 RVR for an year now. My HTPC is connected to it via HDMI from a Amd Radeon HD6950 and from the AVR signal goes to Sony KDL-46HX755 tv. The problem is that I just cannot get DTS-HD master audio working. Same goes for Dolby TrueHD.
Here are the files that I've tested: http://www.mediafire.com/?ztd9kdinrisgmc1 and http://www.mediafire.com/?n0al1et5rs4eb63
I searched the forums and there was something about EDIB? No idea what that is.. Anyway that should be fixed now with new AMD drivers.
I have set up my media player using this guide http://www.torrent-invites.com/audio-video/191921-mpc-hc-madvr-setup-guide.html
Well in MPC the audio is working but it drops it to core DTS. I tried it with XBMC and the video was stuttering a lot. Also I didn't get any sound.
I simply don't have any idea what to do anymore so I'm humbly asking for help.
Thank you in advance!
Ahvir is offline
post #2 of 4 Old 01-20-2013, 08:11 AM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
You need to enable HD Audio in system sounds in control panel I believe after making sure you have the latest drivers for you video card installed.
Sammy2 is offline
post #3 of 4 Old 01-20-2013, 10:00 AM
Andrew Hornfeck's Avatar
Quoted: 31 Post(s)
IN your HDMI Audio control panel you must verify HDCP and the supported modes and have the HD formats selected. This is a core function without being SUPPORTED and checked you will not get them to pass....
Andrew Hornfeck is offline
post #4 of 4 Old 01-20-2013, 10:09 AM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
AFAIK it's not fixed yet. Try any of the EDIDs closer to your TV specs listed in my sig. link.
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
Reply Home Theater Computers
