UHD 4k video cards - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-18-2013, 07:07 AM - Thread Starter
garyrall's Avatar
going to build a new HTPC and was wondering if any quiet video cards are available that can output 4K resolution Ultra High Definition? I know my next display will be UHD so just trying to get it right from the start. Also, Netflix just announced super HD but said it is limited to Windows8 with no mention of Windows7. Dose anyone know why Windows7 would not work since there were no changes made to media center for windows8?.
Here is some of my Stuff: Media Center Pc
garyrall is offline
post #2 of 13 Old 01-18-2013, 07:12 AM
vladd's Avatar
Liked: 39
Super HD is not available in the Media Center plugin. It is only available in the Netflix Metro app. (No Metro apps on Win7.)
vladd is offline
post #3 of 13 Old 01-18-2013, 10:36 AM
tman247's Avatar
Quoted: 58 Post(s)
Liked: 53
But 'super HD' for Netflix is still likely to be way lower quality than standard full HD blu-ray. It's just a marketing ploy to get people to buy in.
tman247 is offline
post #4 of 13 Old 01-18-2013, 10:37 AM
Aluminum's Avatar
Quoted: 22 Post(s)
Liked: 25
There are some fanless GCN-Core Radeons that can output 4K over displayport 1.2, I've seen up to 7750 at least. Can't get much quieter than that.
True Kepler-Core Nvidia 6xx series cards also support it. (beware: on the low end both amd and nvidia do stupid rebranding of older cores with new numbers)
Honestly though by the time 4k screens are a reasonable price (several years) just about any gpu should be able to handle it fine.
My next computer screen upgrade will be 4k for sure but considering that is just becoming available at around 6 grand for 32", the 30" 1600p I got for 1k a few years back has a lot of life left in it.
When I stopped caring about super quiet: E5 1680v2 @ 4.5Ghz, 980ti, i750 SSD - JS9500 & Dell P2715Q for dual 4k@60 because reasons
SAN shares over 56Gb infiniband, microcenter + fleabay = severe risks to my wallet
Aluminum is offline
post #5 of 13 Old 01-18-2013, 10:42 AM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
How about just directly navigating to the netflix web page?
BTW, I don't see how the internet back bone in the U.S. is going to handle 100,000,000 households streaming 30mbps HD content so this is still a ways off I think.
Sammy2 is online now
post #6 of 13 Old 01-18-2013, 10:43 AM
vladd's Avatar
Liked: 39
Not just "likely", it is.
Netflix Super HD: ~5mbps bitrate (maybe a little higher but most likely capped below 10mbps)
Bluray: 20 - 40mbps bitrate
vladd is offline
post #7 of 13 Old 01-18-2013, 10:45 AM
vladd's Avatar
Liked: 39
Possibly, I don't know. If that's the case, I'm not sure why Win7 wouldn't work if you have the IE10 beta installed. Probably an MF decoder issue.
I haven't used Netflix in quite a while.
vladd is offline
post #8 of 13 Old 01-18-2013, 10:46 AM
Aluminum's Avatar
Quoted: 22 Post(s)
Liked: 25
It won't be using the internet backbone hardly at all, any streaming worth its salt is using distributed CDNs much closer, typically inside ISPs (localized P2P is being played with too) but you are still right as the last mile in the US needs MAJOR upgrades.
Aluminum is offline
post #9 of 13 Old 01-18-2013, 10:50 AM
vladd's Avatar
Liked: 39
Super HD streaming requires an ISP that is hosting a CDN as part of their Open Connect network. It costs ISP's nothing to join and Netflix will even supply the hardware. See https://signup.netflix.com/openconnect
vladd is offline
post #10 of 13 Old 01-18-2013, 10:54 AM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
[bI haven't used Netflix in quite a while.[/b]
Me either. I've been a member since 1997 but each time they change their model and pricing I quit. I signed up in 1997 for DVD's but then the went to monthly bank account extraction which I did not appreciate so I quit. I re-signed in 2007 when I got a Blu-ray Player with the netflix app but then the jacked their pricing so I quit again. I probably will never go back.
The last mile is the issue. Maybe I should have said that instead. Uverse is the worst. Charter has Fiber to the node but at least the cable from there to every house in my area is that ½" or thicker trunk line cable. That's got to have more bandwidth than what at&t can ever hope to provide.
post #11 of 13 Old 01-18-2013, 10:55 AM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
So we drifted... I don't know anything at all about the OP's question but will watch this thread and see what I learn. biggrin.gif
post #12 of 13 Old 01-18-2013, 10:57 AM
vladd's Avatar
Liked: 39
I personally have no interest in going back either but some people have offered to pay the streaming only subscription for me is I revive my Netflix plugin for NextPVR so I might change my mind. Too bad I can't get Super HD.
I'll stop going OT now.
vladd is offline
post #13 of 13 Old 01-18-2013, 12:49 PM
Aluminum's Avatar
Quoted: 22 Post(s)
Liked: 25
Yeah it generally blows chunks, even in dense areas. Most places that are even a little bit rural are boned with tons of really old copper.
I'm one of the lucky few on "real" fios in which the last mile is fiber all the way to the side of the house, capable of multiple independent gigabit+ connections. Throw in a new ONT and (maybe) upgrade the router for your neighborhood and done.
The ONT part I'm not even sure what the hardware speed cap is, it might only need provisioning to go a lot faster (300+) and I have a GBe jack on it already.
Pretty much OP should save time and money until buying an actual 4k set, since it might be a moot point by then smile.gif
Aluminum is offline
Reply Home Theater Computers
