Low Profile PCIE card with optical out - AVS Forum | Home Theater Discussions And Reviews
Old 01-18-2013, 03:58 PM - Thread Starter
kwed's Avatar
Title says it all. I thought my computer came with one, but it didn't. I thought I found one on newegg, but I can't find it anymore. 5.1 is all I need, don't have a 7.1 setup yet. Any ideas? Thanks in advance.
kwed is offline
Old 01-18-2013, 04:11 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
No 7.1 over optical and no HD Audio either.
Does your AVR have HDMI?
What about your display?
Can you list your HTPC components and operating system?
Sammy2 is offline
Old 01-18-2013, 08:25 PM - Thread Starter
kwed's Avatar
I took an HP Slimline PC and turned it into a htpc. I am running Windows 8 with a Nvidia graphics card with HDMI out. I am running the hdmi to the tv, sharp 60 inch, and then have an optical out of the TV to the AV Receiver. But it is only giving me stereo. I have read around and found that it is a problem with the tv and graphics card communicating. The card can put out 5.1, but it sees that it is going to a tv with only stereo speakers so it only gives stereo to it. So I was going to put in a sound card like this one? http://www.newegg.com/Product/Product.aspx?Item=N82E16829132052 and go from PC to receiver.
My receiver doesn't have an hdmi port on it. My pc is running a second generation i3 as well. I think the card I found will work. Thoughts?
kwed is offline
Old 01-18-2013, 08:34 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I am not sure about splitting the audio from the video. I use HDMI all the way. Someone else on here will know though.
Sammy2 is offline
Old 01-18-2013, 08:44 PM - Thread Starter
kwed's Avatar
I saw a sering with the nvidia control panel that allows you to turn off the sound through the hdmi. I was thinking I would turn it off and run the sound through the optical.
kwed is offline
Old 01-18-2013, 08:45 PM - Thread Starter
kwed's Avatar
Setting in the nvidia control panel.
kwed is offline
