Plasma TV Screen Slighty Blurry annd screen won't fill the entire TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-19-2013, 02:51 AM - Thread Starter
TechGuy05's Avatar
Hi,
My PC is running Windows 7 64 bit Home Premium and I have an AMD Radeon HD 6900 Video Card. I have my PC connected to 2 displays, a 24" Apple Cinema Display and a 42" Panasonic Plasma TV.
My PC is connected to the TV by a 25-30 Foot HDMI Cable. I switch between displays, I don't view both at one time. When I switch over to the TV I notice that fonts, Icons and everything being displayed on the TV seem slightly blurry. The TV's Resolution is set to 1920x1080.
Also the screen doesn't completely fill the entire TV. The screen fills about 96% of the TV, there are thin black bars around the screen.
When I connect my older PC the screen fills the entire TV and everything is sharp, clear and crisp onscreen.
Any help is greatly appreciated
TechGuy05 is offline
post #2 of 12 Old 01-19-2013, 08:08 AM
lockdown571's Avatar
Quoted: 56 Post(s)
Liked: 89
You need to open up Catalyst and turn off overscan compensation.
lockdown571 is offline
post #3 of 12 Old 01-19-2013, 10:06 AM
olyteddy's Avatar
Quoted: 535 Post(s)
Liked: 941
Do you mean the computer video card is set to 1080? If so are you sure your TV is a 1080 set and not a 720?
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #4 of 12 Old 01-19-2013, 11:39 AM
Quoted: 56 Post(s)
Liked: 89
Oh yeah a 42" plasma? Most definitely not 1080p, although it might accept a 1080 signal. It's probably either 1366x768 or 1024x768.
post #5 of 12 Old 01-19-2013, 02:39 PM
sitlet's Avatar
Quoted: 12 Post(s)
This.
sitlet is offline
post #6 of 12 Old 01-20-2013, 10:46 AM
lsilvest's Avatar
I have a 42" Panny and even if the signal is 1080 it will display at 720p which is my standard resolution and I believe that's the same on about all 42" plasmas. My ATI setting is for 720p and I didn't have to mess with the overscan on it. Mine is also on a dual display (set to clone) and the monitor is 1080p. My scaling option is disabled in CCC.
lsilvest is offline
post #7 of 12 Old 01-20-2013, 02:31 PM
Rammitinski's Avatar
Panasonic definitely does make 42", 1920x1080 plasmas.
Rammitinski is offline
post #8 of 12 Old 01-21-2013, 06:09 AM
Quoted: 56 Post(s)
Liked: 89
Source?
post #9 of 12 Old 01-21-2013, 06:59 AM
bryansj's Avatar
Quoted: 1338 Post(s)
Liked: 625
Source?
Here's the first one I clicked http://shop.panasonic.com/shop/model/TC-P42S30?t=specs
Just don't look at the lowest end units and there are plenty of 1080p native 42" displays.
I have a native 1080p 32" LCD in the bedroom.
bryansj is online now
post #10 of 12 Old 01-21-2013, 07:30 AM
olyteddy's Avatar
Quoted: 535 Post(s)
Liked: 941
Point is, what does the OP have?
olyteddy is offline
post #11 of 12 Old 01-21-2013, 07:31 AM
Quoted: 56 Post(s)
Liked: 89
I stand corrected. That must have been a recent development. Small size 1080p LCDs are common, but for a long time the smallest 1080p plasmas were 50".
post #12 of 12 Old 01-21-2013, 07:53 AM
bryansj's Avatar
Liked: 625
2007 recent enough? http://www.pcworld.com/article/137447/article.html
Reply Home Theater Computers
