Unable to dual boot after installing windiws 8 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-19-2013, 05:47 PM - Thread Starter
araghava's Avatar
Sorry if this is not the right forum.
I have 2 partitions on my disk drive. I used to have vista on one and windows 7 on the other.
I reformatted my vista partition and installed windows 8 on it.
after this when my computer boots up it doesn't give me the option of which OS I want. it boots into windows 8 always.
I can see the windows 7 partition thru explorer.
how do I enable dual boot again.
thanks
araghava is offline
post #2 of 5 Old 01-19-2013, 06:33 PM
kwed's Avatar
I think it is defaulted to boot to windows 8. I dual booted the consumer preview and I could choose, you had like 30 seconds. Maybe get into the BIOS and check there.
kwed is offline
post #3 of 5 Old 01-19-2013, 06:46 PM - Thread Starter
araghava's Avatar
i don't have that option. when i go into advanced system settings it only shows windows 8 as a boot option.
apparently i needed to choose custom install when i installed windows 8. since i chose the regular install i'm unable to get to my windows 7 system anymore.
any help is appreciated.
araghava is offline
post #4 of 5 Old 01-19-2013, 08:26 PM
sycochkn's Avatar
This might help or it may make things worse.
http://www.boyans.net/DualBootRepair.html
sycochkn is offline
post #5 of 5 Old 01-20-2013, 08:16 PM - Thread Starter
araghava's Avatar
thanks. i'll check it out. hopefully it will solve my problem
araghava is offline
Reply Home Theater Computers
