Fast Forward / Rewind in WMC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-20-2013, 06:18 AM - Thread Starter
chuga's Avatar
Hi,
I know there are quite a few older posts on this subject, but I have not seen anything recently.
I wanted to know the options for enabling "true" FF and RW capabilities for mkv files...not skipping forward and backward and using the number keys.
Currently I use media browser in wmc7, and FF/RW does not work for mkv (why does it work for video_TS though??)
Does MPC-HC allow for true FF/RW? Does XBMC? are there any other 3rd party programs/solutions out there?
thanks for the help,
Chuga
chuga is offline
post #2 of 7 Old 01-20-2013, 06:52 AM
Shark007's Avatar
Quoted: 88 Post(s)
Liked: 75
Media Control Plugin will allow proper FF/RW when using Media Center
THIS POST on my forum explains how to set it up.
Windows 8 is also supported.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #3 of 7 Old 01-20-2013, 07:06 AM
Sammy2's Avatar
Quoted: 562 Post(s)
Liked: 264
Does that work with MPC-HC or only with the Media Center Player? I'd rather have 23.976 fps over a 3-2 pull down scheme and put up with the skip rather than true >> and << but if I can have both that would be fantastic.
Sammy2 is online now
post #4 of 7 Old 01-20-2013, 07:08 AM
Shark007's Avatar
Quoted: 88 Post(s)
Liked: 75
Media Control is a Media Center plugin based on FFDshow and created by one of the FFDshow developers. The developer has since abandonned the project but a user on my forum has taken up the project.
Shark007 is offline
post #5 of 7 Old 01-20-2013, 07:12 AM
Sammy2's Avatar
Quoted: 562 Post(s)
Liked: 264
I just looked at the screen shots and it looks as if 23.976 fps is possible but it isn't using MadVR but rather EVR (CP)?
Thanks..
post #6 of 7 Old 01-20-2013, 07:15 AM
Sammy2's Avatar
Quoted: 562 Post(s)
Liked: 264
Where is the source code for this located?
I guess this is it:
http://mediacontrolmce.sourceforge.net/
post #7 of 7 Old 01-20-2013, 01:19 PM - Thread Starter
chuga's Avatar
thanks..I'll give this a try and see how it goes.
chuga is offline
Reply Home Theater Computers
