receiver for HTPC with no HDMI issues? - AVS Forum | Home Theater Discussions And Reviews
Old 01-20-2013, 04:34 PM - Thread Starter
bulls's Avatar
Quoted: 65 Post(s)
Liked: 33
these days...are there still issues with receivers and HDMI connections... needing to mess with EDID or having HDMI get disconnected ?
bulls is online now
Old 01-20-2013, 04:54 PM
carsfreak88's Avatar
i am using a denon 3212 with my htpc and have no problems
carsfreak88 is offline
Old 01-20-2013, 05:38 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I don't have issues with my HTPC and Denon 2312ci but the echo is giving me fits.
Sammy2 is offline
Old 01-20-2013, 05:55 PM
Bond 007's Avatar
Quoted: 2372 Post(s)
Liked: 1907
No problems here. What is EDID?
Licence to Kill
Bond 007 is online now
Old 01-20-2013, 06:05 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Electronic Device IDentification.
Sammy2 is offline
Old 01-20-2013, 06:18 PM
Bond 007's Avatar
Liked: 1907
Thank you. I looked it up and its actually Extended Display Identification Data just for the record although I'm sure that you know far more about it than me. smile.gif
Licence to Kill
Toys7505's Avatar
Quoted: 69 Post(s)
Liked: 26
No problems with my Denon 3311 either.......All the receivers shouldn't have a problem with this......if there is a problem, more than likely its the PC side causing it.
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K Reference 200.7 S2, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
Old 01-20-2013, 06:28 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I don't know jack about it but know when it is causing me issues.
Sammy2 is offline
Old 01-20-2013, 06:29 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Toys
^^This
Sammy2 is offline
Old 01-21-2013, 12:25 AM
lovekeiiy's Avatar
Liked: 30
install AnyDVD HD and that may help. It removes a lot of the HDCP so the PC isn't looking for it from the display. It's a major part of how I can play blu ray discs directly using MPC.
lovekeiiy is offline
