Can someone help me setup my new Nvidia 630 card? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-22-2013, 06:13 PM - Thread Starter
rbmcgee's Avatar
Hi all,
I’m caught in HDCP hell. I’m going to try my best to explain it.
Samsung DLP
Pioneer VSX-512-k AVR (1.4 hdmi)
HTPC w/ new Nvidia 630 graphics card (latest 3.10 driver)
Directv H20 (hdmi to avr)
Scenario 1 (audio and video go through avr)
Run hmdi from htpc to avr and hdmi from avr to dlp
Set up nvidia as single monitor (avr+dlp). Control panel reports hdcp compliant. I play a movie. I see and hear the movie. While the movie is still playing, I switch the avr from htpc to directv. Now I’m watching and hearing directv but the nvidia control panel now reports (via remote viewing) that the chain (avr + dlp is not hdcp). I switch back to the htpc and everything has been cut off (hear no audio, see no video). I then switch back to directv and I see and hear that.
Scenario 2 (video directly to dlp and audio through avr):
Run dvi from htpc/630 to dlp and run hdmi from htpc/630 to avr. Setup nvidia as dual monitors – not cloned (dlp and avr+dlp). Once again I play a movie and can see and hear the movie (audio via avr and video dvi directly to dlp) I switch the avr from htpc to directv. Once again, nvidia control panel now reports avr+dlp is not hdcp. I switch back and the dlp (via dvi) is still showing the movie, but there is no audio. If I switch back to directv, it is fine.
I’m trying to understand where the problem lies - htpc/630 or avr or dlp.
I’m thinking the problem is not the avr because I can switch away from directv and then return and there is no problem with hdcp.
I’m thinking the problem is not the dlp because of the same reason.
Therefore I’m thinking the problem must be with the htpc/630 but I’m not sure what to do or if this is just the nature of the beast (I sure hope not).
Any ideas are welcome.
Bob
rbmcgee is offline
post #2 of 4 Old 01-22-2013, 06:19 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Use HDMI.
Stop playback on the HTPC before switching inputs on the AVR.
Switch the input on the AVR to directTV.
Switch the input on the AVR to the HTPC.
Start or resume playback.
Report back results.
Also, on page 3 of the Denon AVR-XX12 thread in the Receivers section there's trouble shooting advice for HTPCs with or without nVidia cards with HDCP issues with Denon AVR's but it s pretty generic in that it doesn't specifically apply to Denons.
Sammy2 is offline
post #3 of 4 Old 01-22-2013, 06:42 PM - Thread Starter
rbmcgee's Avatar
I kinda feel like an idiot here.
As soon as I removed the dvi cable from the htpc and rebooted, everything seems fine. I can switch back and forth without a problem. It's a good thing that I don't need to actually drive 2 displays or need to send the audio to the avr and the video to the display with separate outputs because I just don't see that working.
Bottom line, for me, if I had both an hdmi cable and a dvi cable attached to the 630 at the same time, I entered hdcp hell. As long as I only have an hdmi cable, I seem to be fine.
Thanks sammy, believe it or not it was your response that prompted me in that direction.
Bob
Testing will continue
Bob
rbmcgee is offline
post #4 of 4 Old 01-22-2013, 07:24 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Oh I didn't realize you had DVI and HDMI connected at the same time or would have mentioned that. HDMI is finicky with other things connected.
Sammy2 is offline
Reply Home Theater Computers
